Evening all,
My 325 cab has developed an increasingly frequent problem where the starter motor doesn't kick in at all. I've already tried the "whacking the motor whilst with key in starter motor position" method, with no joy. Testing the voltage at the solenoid shows there's no juice getting to it even.
However, there is a buzzing noise coming from the right-hand most corner of the dash when I turn the key fully clockwise. I'm guessing there's a relay there that's on it's way out. If I keep trying, it will eventually kick in, but the number of times I have to try seems to be increasing.
Thoughts/suggestions/advice/clues/offers of help all welcomed!
Intermittent starter motor problems - not solenoid
PeteE30Tourer
Back behind an M20, but now I can hear it better.
- **BANNED**
No relays live on the r/h side of the dash,except for the flasher one mounted on the column...
I'm wondering if your ign switch is playing hard to get...
Key turns in the ign barrel,the switch it's self is a seperate component mounted on the back of the barrel,take the lower column shroud off and look for a orange plastic part held to the barrel with a pair of spring tag thingys.Small screwdriver to lift the tags and it should drop into your hand,then insert your screwdriver where the barrel plunger fits and see if the starter works.
Youth is wasted on the young.
None put there by BMW, but never underestimate what the alarm/immobiliser fitters have been up to!daimlerman wrote:No relays live on the r/h side of the dash
- **BANNED**
Brianmoooore wrote:None put there by BMW, but never underestimate what the alarm/immobiliser fitters have been up to!daimlerman wrote:No relays live on the r/h side of the dash
Brian,do you feel ign switch is a possible culprit here?
PeteE30Tourer
Thanks for the suggestions guys. Having had another play (damn thing hardly starts at all now!), the buzzing noise appears to be coming from under the dash - where the car alarm module lives! Brian's on the ball as usual! I thought I'd disabled it all as it caused me so much pain at the beginning of this year, but I guess there's something gradually failing in there that's preventing connection to the starter motor. It's too cold and dark out for me to go digging further, but I'll have a go tomorrow sometime.
Just as a second thought - the ECU is under there also - couldn't be anything to do with that could it?
