Bad wobble/shake
cjdonny
Post Tue Nov 22, 2011 2:43 pm
when driving steering wheel will shake a bit
but when i brake it gets a lot worse :?
it had new disc and pads on front but one(driver side) the old disc i smashed off :o: as the screw was rounded,i also wedged a screwdriver at back of the plate
have i damaged the brearing(pulling it out pushing on it)? or just not fitted the brakes right :cry:
it does need new braking fluid as its brown
any ideas welcome winkeye
pac1982
Post Tue Nov 22, 2011 2:46 pm
Could be all sorts of things but i would imagine your brute force has bent/broken something if i were you i would take it to a garage and get it fixed as it sound like if you have a go at it again you may brake something else.
Not having a dig mate just being honest
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
**BANNED**
Post Tue Nov 22, 2011 4:01 pm
I would have a look at the wishbone rear bush,bet that they are all loose and floppy.
Another possible is one or both of the outer balljoints,especially on the side you used a bit of,um,force on...
BTW,I use Mr Angle Grinder to take the heads off the disc retaining screws!
Youth is wasted on the young.
randomspeedfreak
Post Tue Nov 22, 2011 6:27 pm
most probably bent brake disk id guess
suedenim
Post Wed Nov 23, 2011 10:31 am
Loose wheel?
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
m_jermyn
Post Wed Nov 23, 2011 11:27 am
Warped brake disks... Get new ones
cjdonny
Post Wed Nov 23, 2011 11:40 am
they are new
318 IS
m_jermyn
Post Wed Nov 23, 2011 11:49 am
How new?
Has the wobble only started when you fitted new disks?
What brand?
cjdonny
Post Wed Nov 23, 2011 11:59 am
around 150mile
Brembo discs & GSF mid value pads
picked up car it drove crap put it down to the brakes that were shot,so fitted new ones and serviced it, took it for test passed ok
but got the shake wobble: more when braking
thanks for replys,i will take it to garage this week and get them to have a genral look at ball joints/suspension
cjdonny
Post Wed Nov 30, 2011 4:29 pm
pads not fitted correctly :o:
but needs drop links and 2 shockers :?
318 IS
