Hi, can someone tell me exactly how I test the blue temp sensor resistance at the ECU end. Loads of posts telling people to check it when having cold start issues but not may explaining how.
I assume I remove the big plug from the ECU then test the resistance across two of the pins on the big plug but which two?
The resistance at the sensor is just under 2000 when cold and around 350 when warm.
Just want to rule out an issues with the wiring going from the sensor to the ECU.
Testing Resistance of the blue temp sensor at ECU
Rtaylor2208
Grrrmachine
- E30 Zone Wiki / Team Member
- **BANNED**
Your blue sensor tests OK.
Peel back the rubber boot to check the wire colours,and look for the same at the ECU plug.
The harness for the temp sensors passes through two harness plugs,the one known for giving problems is C191,located under the inlet manifold.
Youth is wasted on the young.
Rtaylor2208
Excellent thanks GrrrMachine and Daimlerman
Rtaylor2208
Checked the readings and both are the same give or take at the senor and ECU so that looks OK. While I have the ecu disconnected is there anything else I should check trying to rule out all things that make ths car run lumpy and rich.
Got the TPS sorted so thats ruled out for the moment.
