so the winter is here !
the good news is with the temp control on max the heater blows nice and hot
turn the control to cold and it blows cold
but theres no middle temp when i turn the control it just blows cold right up to max hot which it then cooks us alive
there is a little pipe that comes off the vacum servo pipes in the engine bay to inside the car glove box area this is not connected to anything i assume this pipe has some thing to do with my problem
its a 89 325 touring
any ideas thanks
heater temp control problem
parkin10
Pipe off of the vacuum pipe?? Is this car one of the 0.0001% of E30s that had climate control? More info. needed.
On the rest of E30s, the first few degrees of the temp control's arc is an electrical switch which applies power to the electric heater valve, and shuts off the hot water supply to the matrix. For the rest of the control's rotation the full flow of water passes through the matrix, and the temp. is controlled by a cable operated flap which blends hot and cold air inside the heater box.
parkin10
it has the little pipe
when i got the car i found this pipe with a screw in the end when i was straightening up and refitting the glove box plastics
no idea where it goes ive pulled it off the servo one way valve and blanked it off now
no air con on this bus sadly
parkin10
do you think the fault is in the heater box with the flap
AFAIK, there's no vacuum control involved with E30 climate control anyway, but I've never seen one in any case. Extremely rare.
Seems like it could be a flap problem. Take off the under dash panel and the RH side, and look/feel for movement of the flap as you rotate the dial.
Can't really remember how much you can see with just the panel off. - to see things properly, you'll need to remove the rear centre console first, then the front console.
parkin10
cheers brian now i have an idea were to look
clipper
If the dash or cosoles have ever been out, pay close attention to the cable routing. It's crucial and I find it difficult. In fact mine still isn't right after 3 attempts.
parkin10
yes i have had it out
then when i came to use a sat nav the cig lighter dident work left a wire off
Billwill
Could be the circuit board that the temp control knob mounts on.....or the other circuit board attached to that!
Try to get the complete temp control assembly from a breaker...and hope you get a good one!
If have the scenaria of max heat or max cold and nothing in between...it usually is one of the circuit boards mentioned above.....the track behind the temp control knob tends to crack from people bumping the control knob.
The electrical part of the heater control is working perfectly, according to the OP's description. It's the mechanical part that appears not to function.Billwill wrote:Could be the circuit board that the temp control knob mounts on.....or the other circuit board attached to that!
Sounds like you may be talking about a climate control version.
Billwill
Brianmoooore wrote:The electrical part of the heater control is working perfectly, according to the OP's description. It's the mechanical part that appears not to function.Billwill wrote:Could be the circuit board that the temp control knob mounts on.....or the other circuit board attached to that!
Yes I could possibly be refering to a climate control system, I agree with your first reply...the first few degrees of movement of the temp knob opens the valve to allow hot water through. I do have an aircon fitted and there is a small internal temp sensor that plays a part in the air con function and regulates the evaporator temperature in conjunction with the temp control so maybe this control panel is only relevant to our air con systems....I know I had the exact same problem on my present 318i M40 and replaced the temperature control circuitry to fix it.
parkin10
not had the chance to look as yet
will post up when i find
cheers all for your help
