Subaru Impreza Calipers
Robbo-80
Post Thu Nov 17, 2011 9:29 pm
Looking into buying a set of Subaru Impreza Front Calipers for my E30. Can anyone point me in the right direction of Discs i would need to get.
Also does anyone have the link to the machine drawings for the brackets for fitting the Calipers?
Any help would be very much appreciated.
e301988325i
Post Sat Nov 19, 2011 3:07 pm
Never heard of using them TBH, under 15" BBS wheels then VW Corrado G60 discs are 20mm bigger in diameter at 280mm but the mounting flange is 2mm thinner at 5mm, Keri WMS sells 2mm spacers to get the wheel back to the standard position.
I said:
e30topless said:
lock the wife in there
BadDave
Post Sun Nov 20, 2011 3:10 pm
Realisticly,it's an uncommon caliper choice.
It could be done,and will take time and require a bit of trial and error to figure out what's needed re wheel offset,disk offset,disk diameter etc.
G60 disks may work if the lug mountings of the Scooby calipers are pretty similar to RX7 ones.
keri-WMS
Post Mon Nov 21, 2011 2:01 am
I've got a feeling they are cast iron as well? Could be wrong.
HairyScreech
Post Mon Nov 21, 2011 9:31 am
which impreza calipers? as there has been many versions.
