Hi,
I would like to know if there are better cooling radiators which or more or less straight fit from other cars for an e30 facelift m20
i know have a 320i with m20b20 but i am building a m20b29 with camshaft and bigger valves and ...
thanks in advance for the help
e30 m20 2.9 cooling options
hongkongfuey
- Mad-tango-geezer
Add an electric fan
with cars like mine,
tropical spec radiator, they're 100mm wider and 100mm deeper than a stock rad. The longer different top hose is £15 from bmw, bottom one is the same
reggid
a good stock cooling system should be upto the job. We run in 43*C plus here........
E30 325is with M20B31
Mikey_Boy
If you are going to track it, then I would suggest the tropical radiator suggested above (Reggid - surely yours has one of these already??)
If not, then the standard system will be juuuuuuuuust good enough for the job...
Depending on where you are in the world, you might also consider an electric fan as well and use that to either bin or supplement the viscous unit..
Good luck!
Good luck!
An electric fan will have nothing like the performance of the viscous fan, and, for matching airflow, will absorb a lot more engine power.
The standard system, in good condition, isn't marginal in any way, but, if you want more capacity, there are many rads from the BMW range that can be fitted into an E30 using an appropriate combination of bottom mounts, and there's usually a hose that will fit as well.
Andyboy
- Alpina Colada
I've a feeling the manual E34 530i/535i rad fits.
e301988325i
Direct fit with the same hoses is a rad for a manual 325i with aircon which is 100mm deeper. best to order with the matching plastic ducting that fits behind the kidney grills.
If you're using the car hard I'd suggest fitting the oil cooler from a sport, if you do try to fill the pipes with oil before fitting to prime the system.
I said:
e30topless said:
lock the wife in there
reggid
It's a dry heat....lol. I don't know tbh but at some point the engine mount crapped itself and left a nice impression so it is far from optimal and have been meaning to replace it.
Mikey_Boy wrote:If you are going to track it, then I would suggest the tropical radiator suggested above (Reggid - surely yours has one of these already??)
Good luck!
Gabriel
I have a oilcooler from a 325i ready to put in
and will try the stock radiator at first
if i see its getting hot i wil try to find some upgrade but i don't think i will find a tropical fan second hand in this region (Belgium)(and new will be very expensive i think) so will be looking for some other fittable radiators
Thanks for the info
Thanks for the info
