Hi,
I am building a 2.9 m20 with camshaft and bigger valves and ...
But my question is will my driveshaft be strong enough for this kind of engine?
I have a 320i
I could put in a 325i driveshaft but will a 325i driveshaft be strong enough for this setup
And i am planning on turboing this engine in the future
What driveshaft do you guys have with high hp turbo setups?
What do you guys suggest?
Thanks for the help
m20 stronger driveshaft options
Morat
From what I've read on E30tech, you should be OK with standard tyre sizes but if you're going towards drag slicks then you'll need be looking at a beefier rear end including diff and diff hanger.
Gabriel
I am now running with 225 tyres in the back but am planning to upgrade to 245 toyo proxes
drive shafts will take it no problem, they're good for about 300lbs of torque so i've seen
I'd like to see you try and get 245 tyres on the back!
