when we removed the m40 motor out of my car to put in the m52, noone made a note of which of the fuel lines coming into the bay are which,
there are 3 lines, which is inlet, retun and one other?!
also as im not at the garage could someone tell me if we are 6mm fuel line or 8mm?
Fuel line confusion
randomspeedfreak
andy523
The 3rd line is the vent pipe from the tank, and they are all 8mm.
- **BANNED**
Pipe coming via the filter should be the feed,goes to the fuel rail.
Other one should be the return,goes to the FPR.
Youth is wasted on the young.
randomspeedfreak
okay cheers lads thanks for that
randomspeedfreak
Why does the vent come all the way to the engine bay?! Is there an easy way to tell which pipe is which?
andy523
thats what i thought when replacing the lines, but i used a hard plastic pipe which you heat up and bend when replacing the vent pipe.
Vent pipe is the one that runs separately along part of the underside of the car from the other two fuel lines, and is likely to be the most corroded.randomspeedfreak wrote:Why does the vent come all the way to the engine bay?! Is there an easy way to tell which pipe is which?
Pipe comes all the way to the engine bay, so that it can be fed back into the engine on cars with emissions equipment. There's no reason why you can't convert to it ending at the back, as it did on earlier cars.
randomspeedfreak
thanks lads ill have a dig tomorrow
