pulse wheel
sammydickie
Has anyone had problems with the pulse wheel that the crank position sensor picks up from? ive bin advised it may be the cause of a strange but violent cut in the engine power when at peak output and high rpm? I know that its a damper also, as it has rubber built into it. Any thoughts....
Mikey_Boy
The trigger wheel shouldn't cause any issues - even if your crank damper does wiggle around a little as it damps, the torsional won't vary the engine speed signal enough to cause the engine speed signal to 'drop out' as you have been advised..
I would look elsewhere in your ignition system if you do find this problem. I have thrashed the guts off my M20 donk and never ever had this issue...
Alternatively, you could just be hitting the Rev Limiter...
sammydickie
def not rev limit! but there is a massive drop out, its really getting to me now! spent a lot of time and money on this!
Has no one else had these symptoms? It doesnt feel like a misfire or a burble, but more sudden and violent, then manages to get past it and rev on to around 7k limit!
- **BANNED**
7k limit is a bit high....mine is about 6400rpm...
Youth is wasted on the young.
hongkongfuey
- Mad-tango-geezer
Have you chipped your ecu ?
with cars like mine,
