Steering Rack Question
turkeysneck
Post Fri Nov 18, 2011 9:54 pm
I'm changing the steering rack for a Z3 or an E46 rack, I've got a cheaper end Hot Tuning manifold, am I going to have problems with the new rack fouling the pipes.
Mikey_Boy
Post Fri Nov 18, 2011 10:42 pm
Quite possibly... :(
turkeysneck
Post Fri Nov 18, 2011 10:58 pm
OK but does anybody actually know for sure.
b12rlw
Post Fri Nov 18, 2011 11:14 pm
you soon will, once attempting to fit it. some combos of parts work others dont, only way to know for sue is to try and fit them.
HairyScreech
Post Sat Nov 19, 2011 1:44 am
i would expect clearance to be tight and i would think that the exhausts or the linkage would need modification.
probably both.
**BANNED**
Post Sat Nov 19, 2011 1:49 am
You will not be able to use an E36/46 rack with a Hottuning manifold.
Unless you modify the front crossmember by moving the rack mounting tabs.This is not something that I would suggest is suitable as a modification,unless you,or the person carrying out the work,is a qualified engineer.
Youth is wasted on the young.
hongkongfuey
Mad-tango-geezer
Post Sat Nov 19, 2011 8:14 am
What part would hit the manifold?
with cars like mine,
e301988325i
Post Sat Nov 19, 2011 10:23 am
Rob you might get away with one of DanThe's linkage rods which remove the coupling in the middle, I think the thread was in the group buy section. Whichever way you go it's going to be trial and error with the car off the road IMHO
I said:
e30topless said:
lock the wife in there
**BANNED**
Post Sat Nov 19, 2011 10:37 am
hongkongfuey wrote:What part would hit the manifold?
I would expect the steering guibo to foul.
My answer above is based on work done by Temple30 some years back,he fitted a quicker rack with one of the initial run of BTB1 manifolds.I cannot remember the detail,but he needed to move the rack mounting tabs to the left an inch or so.The end result was a car with more steering lock in one direction...
Now the solid lower link is available from Dan,it may be possible without this kind of modification,but the safe answer to 'will a quicker rack fit with Hottuning' must,I feel,remain,not without other work!
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 9:31 am
I got a e36 rack with the already made up link, e36 top e34 was bought from the zone
e301988325i
Post Sun Nov 20, 2011 10:04 am
Is yours the same sa in this link, which does away with the centre coupling for increased clearance?
http://www.e30zone.net/modules.php?name ... 45&start=0
I said:
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 12:18 pm
no, it has the waffeled/crinkled top part from e36 and the guibo 2/3 down ill get a pic up
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 5:46 pm
e301988325i
Post Sun Nov 20, 2011 6:17 pm
Don't bother trying to fit until you get one of DanThe's linkage assemblies IMHO.
I said:
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 7:07 pm
if i turn it upside down the guibo should miss?
Post Sun Nov 20, 2011 10:35 pm
There's a limited space on an E30 where both the steering linkage and the exhaust primaries have to co exist. Because of this, all RH drive manifolds aim for the space where the E30 linkage isn't.
Because of the different pinion angle of the E36/46 racks, when converting to one of these, it's just about inevitable that the manifold primaries will already be occupying that space, and mods. need to be made.
Anyone ever tried using an E36/46 rack on a RH drive car, using a LH drive manifold? At least this won't be deliberately designed to foul where the linkage needs to be.
