e3o exhausts are they all the same
exup
Boost Junkie
Post Sun Nov 13, 2005 10:29 am
Hi all ,
do all e30s 6 pots share the same exhausts?
ie can u fitt one off a 4 door 1989 one on to a 91 caddy ?
or on to a 90 touring or is it just the front secction or front and middle the same ????
how much is a exhaust now days for a caddy and a touring ?? and whos / wheres the cheapest for m/steel or stainless systems ?
M5pilot
Post Sun Nov 13, 2005 1:04 pm
No they are not all the same. There are two main types, 3 piece and two peice and none of the parts are interchangeable.
Cheapest place for stainless is e30zone shop and for mild steel probably the for sale section or motormec/ECP
All depends on what you want to be honest.
Post Sun Nov 13, 2005 1:46 pm
We've been here before.
My only comment on this is that a few months ago I tried to fit the rear box from a two piece system on a 320 touring, to the front half of a similar age 325 touring.
oth rear boxes laid out on the workshop floor looked identical, but when I tried to fit it, I found the piece of pipe that slides inside another where the two join was about 1mm too big. Close enough, if it had been the other way around, and close enough for the second pipe, but it would not fit untill I put a couple of saw cuts in the outer pipe and enlaged it a bit.
Brian28
Post Sun Nov 13, 2005 2:18 pm
I think (told by a garage) that they are swappable if the complete system is changed, ie from the manifold/front downpipes joint backwards. Happy to be corrected tho.
Brian
For sale - E30 320i racer project - sold.
mrLEE30
Post Sun Nov 13, 2005 2:57 pm
thought the only difference was between 325 and 320 (as brian says the diameters are different), so if it is the same engine (and exhaust configuration ie 2 piece or a 3 piece) then there is no reason why a four door exhaust will not fit on your cab, and yes the entire system is interchangable (brackets may need to be changed too) that is to say you can put a 325 or 320 exhaust system (manifold to silencer) onto any other 6pot car, and no difference between 2 door, 4 door, cab and touring.
as all car share the same wheel base etc.
mrlee
