Water in boot well
thecode
Post Wed Nov 16, 2011 10:50 pm
discovered a pond in the off side boot well, cant figure were the water is entering, boot seal seems fine taped up the rear light to see if it was the light seal but doesn't seem to be ether of them, any ideas were to look next. :cry:
Barx325i
Post Wed Nov 16, 2011 10:54 pm
the spot weld, that secures the boot hinge anchor point to the boot gutter, just below the rear screen.. is a contender
Post Wed Nov 16, 2011 11:00 pm
pull out the side carpet that covers the inner wheel arch and get a torch and see if you can see outside world where the arch meets the 1/4 panel :)
LLamaFarm
Post Thu Nov 17, 2011 2:11 pm
just above the rear lights & beneath the boot seal was my culprit before it all got welded up and resprayed. use a watering can to pour water in the gutter runners and you will get your answer :) failing that get a small child to sit in the boot with a torch lol (joke) :mad:
Motorhole
Post Thu Nov 17, 2011 2:12 pm
E30BeemerLad wrote:pull out the side carpet that covers the inner wheel arch and get a torch and see if you can see outside world where the arch meets the 1/4 panel :)
+1
thecode
Post Thu Nov 17, 2011 6:14 pm
Its a touring should of made it a bit more clear, sorry
Post Thu Nov 17, 2011 6:25 pm
Possibilities then really are
1- your rear inner arches are rotten and water is spraying in from the tyre treads
2- rear light seals are fubar
3- tailgate seals are fubar
4- sunroof drain pipes blocked, dislodged or rusted in the rooflining and leaking from up there - is your headlining sagging in the rear?
5- battery tray is rotten underneath
That's my take on it
thecode
Post Thu Nov 17, 2011 11:16 pm
E30BeemerLad wrote:Possibilities then really are
thanks for the info, how can i check number 4
Post Fri Nov 18, 2011 7:26 am
The only way to properly check is to drop the headlining which isnt something you should enter into lightly.
The usual suspects are the rear light seals, closely followed by a hole in the rear inner arch which will be hidden currently by the sound deadening material.
This is what you're looking for :
This was also on a touring shell - caused by the fuel filler neck causing a buildup of mud to be held against the bodywork under the arch.
KimH
Post Sat Nov 19, 2011 8:10 pm
If you've a sunroof, water running onto the off-side sunroof tray will drain forwards to a hole that is visible with the roof retracted and out of the sill behind the front wheel. If the car is on an incline draining water to the rear, there is a tube running inside the C pillar that connects the sunroof tray to the hidden vent behind the off-side part of the rear bumper. (you can see its nearside counterpart in front of the left hand mounted rear wash-wipe bottle).
Park your car on a slight uphill incline, pour a little water directly onto the open roof's channel and wait for it to drip behind the rear wheel. If it does - your drains are OK and the problem lays elsewhere.
If not, and you're lucky, the tube is either blocked or has come adrift from the socket in the side vent.
If not, and you aren't lucky, check the rear footwell and the rear seat bench carpet for dampness.
On mine, the rear drain tube had rusted completely off the sunroof tray and water simply rained down the C pillar into the rear passenger footwell and into the rear cubby hole.
Good luck with this.
Barx325i
Post Sat Nov 19, 2011 8:52 pm
I've never had to check this one, but access once suitably watered give it a blast with an air line.. If it'd blocked it may clear the obstruction, however this clearance may be perpendicular to the drain hole
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Nov 19, 2011 9:02 pm
capri_rob wrote:This is what you're looking for :
I can confirm this; I cut exactly the same hole out of my touring last month.
