head gasket m40 symptoms?
markus_74
Post Wed Nov 16, 2011 2:25 pm
hello,
I have m40 engine that always loses coolant, it start 100cc for 200 miles a year ago and at this moment 1000cc for 50miles.
temp gauge is still at normal at half and below, but if my car stop from a trip the water come out from the coolant cap.
I try check all plugs all the electrode has the color of RED like a brick and when open the number 1 plug I feel there is harsh and dry and no oil.
every morning I try to open my radiator cap I feel it is difficult to open.
no water leak from hose etc as I have replace with new radiator and new 1.4 bar radiator cap.
does this mean that my head gasket is blown/failed?
need help for head gasket blown symptoms and how I will know it will need resurface or not?
thank you in advance
markus
mattrs
Post Wed Nov 16, 2011 2:46 pm
Usual symptoms for any car mate, overheating or emulsion (creamy coloured goop or weird colour i.e. not golden brown or black) on oil cap, dip stick or coolant cap. (if its just on the oil cap or dipstick it may only be condensation on some cars).
Also look for back pressure or eggy/exhaust smell from coolant bottle.
I don't know much about these but an m20 coolant tank can be opened when running without drama even at working temperature.
Finally, I am no expert but it may just be your fan or something simple. The fact the coolant cap is difficult to remove is probably just ware and wouldn't personaly worry me!
markus_74
Post Wed Nov 16, 2011 2:56 pm
no creamy oil+water, but water loose without any sign of leak and temperature is normal.
if the water loose to much without I know the temp gauge will go pass the half and the rest of water will come out from radiator cap.
HairyScreech
Post Wed Nov 16, 2011 9:56 pm
if its running fine and theres no mayo and its not pressurising the system to the point of popping hoses, and all 4 spark plugs are light brown kinda like mouse fur coloured then i wouldnt worry about the head gasket.
mine has a small pin hole leak in a hose, that when hot atomises the coolant out at a rate of about 1l a month.
iv given up looking for it as its no biggie and not really the end of the world.
the cap will be hard to remove as it leaks a bit under pressure via the pin hole and then cools down, sucking the cap down with the contraction of the liquid.
greg124
Post Thu Nov 17, 2011 3:16 pm
Could be a paritially clogged radiator/cooling system, over-pressurising the cooling system and forcing steam out of the radiator cap, which is why you can't see any water.
If corrosion/limescale/crud has been building up in the cooling system over the last year, it would explain why the problem has been getting worse.
I'd try 'Radflush' or similar
Schadenfreude - the German's haven't got a word for that.
