Carnt open passenger door
cjdonny
Post Sat Nov 12, 2011 3:52 pm
all was fine until other day :twisted:
the passenger door wont open with the key in door barrel or central locking using the other door barrel
also tried from the inside and wont budge any ideas please
tried some wd40 in the key hole no luck :?
Darrenr
Post Sat Nov 12, 2011 3:57 pm
mine did this to the solinoid locked up solid i just removed the 2 bolts to release the solinoid so that i could open then door.
still havent found out the problem tho
cjdonny
Post Sat Nov 12, 2011 3:59 pm
also it WILL lock from the passenger side but the key wont turn to open?
318 IS
E30LI
Post Sat Nov 12, 2011 4:16 pm
For me when I had a similar problem it was the central locking module that had gone... which on mine was in the driver footwell behind the speaker compartment. See you're from Donny too, if all else fails you can come over and try mine in it and see if it makes any difference if you wanna.
**BANNED**
Post Sat Nov 12, 2011 5:19 pm
If the key will move only in one direction,then I would suspect that the latching gear in the door jamb needs removal,cleaning,lubricating and working by hand until it moves freely with a light action.
There is also a sporting chance that the lock barrel has been damaged,these seem to fail at the L shaped operating arm.It's not apparent that the arm is broken until the barrel is dismantled,if the arm is in two or more bits,it's broken!
Cure here is a 'Lock Repair Kit' from your local friendly dealer for about £20.You get a bag of bits to build a new lock barrel to suit your key.
Cleaning and lubricating the operating gear,a new lock barrel,and your door will function properly for another 20 years...
Youth is wasted on the young.
cjdonny
Post Sat Nov 12, 2011 8:05 pm
thanks for info
So how do i open the door to get to the inside? :?
318 IS
cjdonny
Post Tue Nov 15, 2011 11:47 pm
looked at back of the driver side speaker lots of wires! not sure i can see a relay
might have to pop rnd with it
this stopped working other week when someone pulled the passenger handel before i opened the door if it makes any diffrence
318 IS
Post Wed Nov 16, 2011 9:27 am
Remove the passenger seat and then take off the door card
Remove the two 7mm self tapping screws just under the rear edge of the card, about half way down, to release the locking motor, and see if that allows you to open the door.
cjdonny
Post Wed Nov 16, 2011 10:45 am
thanks 8)
318 IS
cjdonny
Post Mon Nov 21, 2011 4:28 pm
Got the door open pushing and turning key,found the actuator was stuck.freed it. Re fitted all working fine.put door card bk on stoped working again! If I had not laughed I would have cried! So looks like I need another :twisted:
318 IS
cjdonny
Post Sat Nov 26, 2011 12:29 pm
Right got another thats free to move (mine was jammed solid) fitted it it still not working will work once either close open but making a groining sound? is this one duff too?
318 IS
Post Sat Nov 26, 2011 2:04 pm
Didn't it occur to you to wonder why the original actuator was "jammed solid"?
Chances are that there's water in the locking ECU, as a result of the sill drains not being kept clear, and that it has cooked your replacement actuator, just like it did the first one.
cjdonny
Post Sat Nov 26, 2011 3:55 pm
Locking ecu? I just plugged it in hanging out the door 2 try it
318 IS
cjdonny
Post Wed Nov 30, 2011 4:31 pm
sorted 8)
sent me out a replacment all works fine
now must have been a wrong un :wink:
318 IS
