clio servo
BATTS91
Post Tue Nov 15, 2011 3:25 pm
right my brakes still arnt working properly my spacer makes the rod the exact same size as an e30 one but when the engine is running and i push the peddle the first inch on the peddle feels like air BUT
when i test the brakes driving back and fourth on the driveway in this part that feels like air the brakes are sharp im thinking that my servo may be past its sell by date as when i take the master off and looked at it all the rod that goes into master has alot of movement left to righ up and down im still yet to try another servo but is this movement normal as the e30 one doesnt move about its solid?
also why use the e30 master when the clio can be used easily would it be because of the pipe routing or looking original for the homos ???
bimanut
Post Tue Nov 15, 2011 5:32 pm
The rod on my clio servo waggles about a bit aswell.Dont know about anyone elses reason but i used the E30 master cuz it was easier and its all plumbed in and dont have to worry about trying to bleed the ABS unit :)
Post Wed Nov 16, 2011 8:25 am
The push rod is meant to move, the reason you keep the E30 master cylinder is because its matched to the E30 brake calipers, the clio master cylinder has a smaller bore and your brakes will be less effective
BATTS91
Post Wed Nov 16, 2011 2:28 pm
aha i got ya danthe , i cant belive im having so much agg with this i dont understand if that rod in the clio servo is supposed to have movement ill try another e30 master i have one in the garage somewhere i know that the rod is the correct lengh as ive measured and triple measure how long the e30 is n how long mine is now with a spacer i cant get my head arounf this
