s50 engine or something else?
badger88
Post Sat Aug 27, 2011 6:28 am
hey
after cmpleting a 318 to 325 conversion i now want alot more power so i have been reading up on the s50 engine and would really like to do this conversion, know i no the exhaust is the pricy bit from btb but i just wanted to now what is the wiring side of things like? im guessing its not going to be plug and play like the last 1 and some scan tools will be required. just after some advise really specially of those who have done this conversion,could you please tell me what gearbox do i use and what other parts do i have to think about, which diff prop linkage ectect.... :D
penton08
Post Sat Aug 27, 2011 3:30 pm
There are quite a few build treads of this swap now, Have a look at them for a proper idea of whats involved. Wiring can be a bit daunting and takes a long time to make it nice. Gear box is the e36 m3(you will need a suitable ratio diff), Prop shaft can be either e30 m3 or e36 328. Most important of all...... Make sure you get a known good engine that you have seen running!!!! After that it is just nuts and bolts, Oh and plenty of ££££'s.
badger88
Post Sun Aug 28, 2011 12:02 pm
:D ok thanks mate i will have a good read, 1 more question tho 3.0 or 3.2?
penton08
Post Sun Aug 28, 2011 3:37 pm
You pay your money, you make your choice :D Mine is a 3.0l and I have done a 3.2l conversion for a customer, His is a cab but mine is faster winkeye In the real world the 3.0l makes 280-95 hp and the evo makes 295-310 hp. Dual vanos rumors are over hyped and bottom end failures are avoidable with ARP's so no need to avoid the evo for reliability issues.
UweM3
Post Sun Aug 28, 2011 4:44 pm
i have a 33k miles 3.2 for sale with new vanos, ARP rod bolts, 5speed box, reflashed ECU(no EWS and other stuff), propshaft, new MAFF, etc etc. but no RHD exhaust.......
badger88
Post Mon Aug 29, 2011 10:14 am
ok what exactly is the vanos and the issueswith them? also what is EWS? ive seen this word pop up in a few differnt forums. how much for the lot to get me started on my conversion uwem3? pm me, penton08 thanx for the quik replies :D
Mikey_Boy
Post Tue Aug 30, 2011 9:30 pm
EWS is the programmed key system used on more modern BMWs - it's linked to the ECU so you need a programmed key, ECU and EWS module - again there are many threads dedicated to this if you do a search...
Going from a 325 to even a 'standard' S50 is one hell of a power jump so please do make sure that your brakes, suspension and bushes are up to the job otherwise you will just spend your time spinning up the rear tyres and not being able to stop!!
I considered an S50 for quite a while (and might still go there!) but my future is S14 powered for that retro bank emptying charm... winkeye
Depends on what you want the car for - daily driver or track monster? Either will suit an S50 just fine, but a good M52 conversion is also very nice...
Good luck!
:thumb:
Superferris
Post Mon Nov 14, 2011 5:46 pm
how much roughly would a s50 conversion cost all in all?
leeparkes
Post Mon Nov 14, 2011 6:05 pm
DIY cost is around 6K.
Superferris
Post Tue Nov 15, 2011 8:25 pm
leeparkes wrote:DIY cost is around 6K.
wow lolzz any one on here can fix an electrical roof... dont know whats rong wif it and the horse shoe flap does not close! :(
Post Tue Nov 15, 2011 10:42 pm
PARDON????
Superferris
Post Wed Nov 16, 2011 11:29 am
DanThe wrote:PARDON????
where you put the soft top into that compatment behind the back seats, the flap shaped as a U shape doesnt close. im not sure whats its actully called lolzz
Post Wed Nov 16, 2011 12:39 pm
This is the Engine Swap Forum, and someone else thread about an S50 engine..
Try Technical Help.
