1994 318i Touring - Time to Sell :(
Dezzy
- CR24v it's a lifestyle
For £550 you defos can't moan!
Looks cracking that mate. L reg, rot free, 1 owner touring ftw!
cheers Dez, need to pop up and see you soon as the winter tyres ive got, one of them needs a new valve and the two front ones on the bbs last about 2 days max and have zero air
kieran325
Bit like Dezzy himslef.Alex wrote: and have zero hair
Looks good.
its Rule number 87 of the Cr24v Handbookkieran325 wrote:Bit like Dezzy himslef.Alex wrote: and have zero hair
Looks good.
Alex just noticed you have the complete design interior now,
put my name on the grey door cards fella
going to sell them comlete with the interior
unless you want the whole interior
have another set in the loft though
cool I will give ya a bell through the week Alex
been playing as you do with a new car
Seems alot quicker than i would expect, faster than any other m40 donk ive driven
0-60 run, note the immense tyre squeel as i pull away in first, this was shifting gear manually as it changes at 4800rpm in D
going to try new fluid and filter.
it would leave my 316i compact for dead, i thought it would be the opposite
click the black square
Ideally it needs an m52
Dezzy
I am officially offended right nowkieran325 wrote:Bit like Dezzy himslef.Alex wrote: and have zero hair
Looks good.
Kedge
Nice work there Alex, car well saved
You going to tidy the bumper scuffs yourself or is that a job at a later date for the painter?
new bumper moldings next month when i get paidKedge wrote:Nice work there Alex, car well saved![]()
Kedge
Proper job!!Alex wrote:new bumper moldings next month when i get paidKedge wrote:Nice work there Alex, car well saved![]()
Once the fogs are fitted, Freshly Painted IS lip, dealer plates and new bumper mouldings on that front bumper its going to look different again
Looking good Alex, not a fan of tourings but this looks nice and clean
I'am not a fan of tourings either its my least fav model
Probably why they don't rust as much
i have often thought, why the fook do i have a touring, but hey ho its rust free
I fancy a baur next time round
Now that's going one step too far
that would be a moredoor, at least you can you the excuse you need luggage space for a touring a 4 door is just pointlessImysE30 wrote:Now that's going one step too far![]()
Spend an hour or so on it today, firstly washed it so it was looking nice again, then decided to have a play about with the front wing, the bodyshop guy said i needed to pry it out a bit and put the screw in that go behind the wing as the door was catching it, however tried this with no luck, i managed to get it so it doesnt catch the door but it looks a right mess, i would say this is why you dont mess about with pattern parts however the painter said the footwell has taken a bit of impact making the door a challange tofit however now its fitted i belive the door sits that tiny bit further forward than where it should fit.
I'am going to try a gen bmw wing and see where i get as i cant leave it as it is as everything else is spot on.
Door strips all fitted too. ive had twp days off work now and plan was to get it all polished fit wing properly, fit dealer plates, IS lip and get fogs fitted however i somehow got caught up in finishing with the Girlfriend
Anyway a few piccys
Crappy wing
Anyway a few piccys
Crappy wing
rrs
Is the door in the correct place at the back edge? If its the same there then could you not shim the hinges to adjust the fitment?
to be honest, i recon the door needs to go down????
but then if the door went down it wouldnt be ligned up with the back door and the back door is absolutly spot on with the gap
rrs
Sounds like your on the right track then and a genuine wing may solve the problem.
oomz1975
they look pretty good with fresh paint dont they, give it a year
THEHOOD
Looking really good!
The joys of being 21, had a few quotes for modified insurance for when i turn 21 in Feb with 4 years no claims
One quote was £1500, one £1200 and one £1050 considering i'am paying £1100 for a 316i compact now i'am more than willing to pay it.
So Spec is as follows.
M20b25 engine
320i Gearbox and Clutch (similar to sport ratio)
Manual conversion
3.91 Diff (lsd if i can afford)
Possibly stick to a single pipe 320i system to prevent hacking of valance (unsure yet)
Budget broken down
Engine £250
Gearbox clutch and manual conversion £100 allready purchased.
Diff Non lsd £50
Cambelt and other serviceable bits £100
£100 on Exhaust
£100 for other bits and pieces i may need
I'am hoping not to spend anymore than £700 hopefully i can pick alot of the bits up cheap as ive got 3 month to get it done, or at least get it all ready to be done.
It was suggested to do an m50 conversion but ive decided to keep it simple, least everything can be bought "off the shelf" so to speak.
Will be picking the 320i gearbox, clutch and manual conversion up on Sunday so its a start
Need to invest in an engine hoist next
M20b25 engine
Manual conversion
Budget broken down
Engine £250
Diff Non lsd £50
£100 on Exhaust
The best overall choice for your budget.
Dont you have a long journey to work though? Thought the sport was to juicy for that?
Thought it was only the pre-facelift 320i that had a single exhaust ? the later cars had twin ones but with smaller bore pipes than the 325i.Alex wrote:Possibly stick to a single pipe 320i system to prevent hacking of valance (unsure yet)
If you want it to look stock you'll need to chop the valance.
Or you could put a single slightly larger bore pipe in - but it would definately look molested then
- Homo Hair
The only 'tricky' bit of an M50 swap can be bought off DanThe..Alex wrote:Engine £250
Diff Non lsd £50
£100 on Exhaust
M20 clutch/flyweel
M40 box/prop/linkage
Diff
M50 Engine - Mine cost me £150
Standard 325i exhaust could be used - Or an aftermarket if you wanted.
45 mins wiring.
Done.
Still think it was doeable for the money and a better end result, esp as you are doing the work yourself. 30 extra ponies and better MPG
Good luck though!
Fell out with various people at work and ended up closer to homebss325i wrote:The best overall choice for your budget.
Well Small update
Ive sourced an engine, has 140k on the clock and coming out of a rotten scottish moredoor, paid £150 for it and the seller is letting me have everything i need cooling system the lot.
Ive also bought a nice shiney 6 branch, nothing flash i just like the look of them more than anything.
Ive also bought a 320i Gearbox, Clutch, Flywheel, Prop and manual conversion etc from Magpie just need to get up to collect it all.
I'am also going to try a single pipe 320i exhaust system so i dont need to cut the rear valance, ive bought a centre section just need a backbox now.
Ive also purchased a used Mauritius blue passanger side front wing, typical once i get my car resprayed a seller lists all the panels i needed in the right colour arrhhh
Not sure how far i will get over the winter as its too cold, hopefully by spring i should be nearly there.
once ive got the car on the road i will invest in some 6 pot 40mm lowering springs and prehaps some new dampers all round.
I'am Allready looking forward to going to meets in summer 2012, bring it omn
Gave the interior a good clean today, a job i keep putting off but so glad ive done it, its came up like new.
Started off with door cards
used the following things
Before pictures
After Pictures
Then did the boot and carpets, used a vax wet vac and some ariel washing powder, much stronger than the proper stuff your suppose to put in it:D
Before
After
then did the carpets, usually i remove the carpet to do this but i can never get the carpet back in the exact place when it goes back in and i want it in the exact place this time. to be honest it isnt much harder, footwells are but nothing you cant solve with a scrubbing brush
Before
During
after
Must of got rid of at least 5 of these, water was black
Next i need to get the leather seats all scrubed up, not going to use my design edition interior now
Before pictures
After Pictures
Before
After
Before
During
after
BEMER_LAND
Does that mean its up for grabsnot going to use my design edition interior now
