So close but STILL no start - help needed please
tom325sport
OK so I have installed a 2.5 M20 facelift engine into my facelift 318i Cab. Trouble is it just won't start. I have done a lot of reading and researching on here and in various books etc.
So here is a run down of the checks and things I have done and replaced.
So the engine is cranking well, my oil pressure light goes out as normal but the engine will not start.
I have power to the DME relay when the key is turned, the fuel pump runs when I bridge the connections, the DME and Fuel pump relays are in good working order, ALL connections to the ECU are present as they have been checked with a multi-meter. Coil checked,and fuse 11 is good!
I have no fuel or spark - I have replaced the crank position sensor but still nothing! I have power going to ECU!!
I've now run out of ideas unless it is a faulty ECU?
Please help?
Please help?
threelander
seems like that to me mate if you got power going in and none comeing out.is the loom ok.do you know the ecu and loom or is it new to you is it the proper ecu or a duff loom is my guess matebut no expert sorry
Jim320i
- E30 Zone News / COTM Team
Have you checked to see if you have fuel getting to the rail?
I had a similiar issue when I switched a 2.5 for a 2.5... Turned out to be a dodgy wire going into the fuel pump relay, causing it not to get any fuel... Only figured it out by accident after about 3 weekends of trying to figure out what was up with it... My old man put his weight on it while leaning while I was trying to fire it again and it started... He moved his hand and then it cut out a few seconds later... Some investigating found a wire not all the way in
there are 2 small identical plugs (black) under the diagnostic plug, one is from the pulse sensor on the HT lead the other is the crank sensor,
try switch them around, no spark or fuel could indicate no signal from the CPS
tom325sport
Jim - Yes no fuel getting to the rail! I'll check the wires going into the fuel pump relay.
Yes I've swooped them over and still nothing. The loom was with the engine when I bought it - it was in a box though. The ECU has the code 173 at the end and it has a 'mild chip' fitted if that helps?
Any other ideas when I check it again on Sunday?
Jim320i
Have a read through my thread when I had the same issue mate...
http://www.e30zone.net/modules.php?name ... 20&start=0
Lots of suggestions at the time of what to test.
tom325sport
Jim - that's great!!
I'll have a read through now.
tom325sport
OK got some checking to do tomorrow - Is there anything else anyone can suggest?
Jim320i
You've made sure there is fuel in the tank havent you?
tom325sport
Erm......... Yes I put £10 in! The tank was empty though as I replaced it - the one I had off you I think .
Do you think it needs more than that?
Jim320i
I'd stick a bit more in and just double check its not pishing out the bottom when your trying to turn it over? Just by the off chance...
And yes, that would be the tank... I should have mentioned the 2 inch hole directly at the bottom?
Joking by the way
Joking by the way
- **BANNED**
Fuel lines the correct way round?
Youth is wasted on the young.
tom325sport
OK will do! When I first cranked it over the first time I'd not tightened a hose near the fuel filter and it pished out near the fuel filter!
I got scared then - then I read the last comment
tom325sport
Malc - I will double check again but I followed them all the way from the fuel filter to the engine.
- **BANNED**
Feed goes to the open end of the fuel rail,return from the FPR.There seems to be two types of fuel rail,some with the feed at the bulkhead end,some with it under/alongside the FPR.
early fuel rail has feed at the bulkhead,
the "upper steel fuel pipe" that runs up the inner wing feeds the FPR
tom325sport
So tomorrows jobs:
Check fuel pump relay again - Where does this get it's earth from? ECU?
Check Fuel lines are the correct way round.
Put MORE fuel in the tank.
Try and get a spare ECU to check it's not that.
Any others??
Any others??
Jim320i
Lots of Tea. Swear words and walking back and forth to post on the zone
tom325sport
Yes plenty of that!!Jim320i wrote:Lots of Tea. Swear words and walking back and forth to post on the zone
tom325sport
Ok so, I have fuel coming into the rail, spark at the plugs but still no start!
I've checked the spark plugs and they are bone dry, should the plugs be wet with fuel??
Please help as I'm starting to swear a lot!
threelander
yes of course they should but you are getting there tom are the injectors ok
Curr946
check the plug under the inlet manifold make sure all the wires are OK both ends
If your wife must learn to drive, don't stand in her way!
tom325sport
Thanks! Yes injectors look ok. I'll be checking the plug now.
Is that the c191?
Is that the c191?
andyp
- True Old Skooler
apart from what was said about the fuel pipes, check that there is no cuts in the loom near the ECU for an immoboliser from a previous alarm, maybe an earth off somewhere ? or crank sensor ?
tom325sport
Crank sensor was changed and now I am getting spark and fuel.
Just checking the feeds from the injectors. Then I'll check plug c191!!!
andyp
- True Old Skooler
spark to the plugs ?
tom325sport
Yes spark at the plugs.
tom325sport
Ok so I've identified I'm getting continuity from the red and white wire from DME to plug c191,
And continuity from red and white wire from the injector side of c191. But
when I plug them together - nothing! So pushed the bottom of the plug up and turned it over and she fired up!!!!
A little bit loud as no exhaust, but it ran while I fiddled with the plug...
Will re-wire next time. Happy though. Thanks for advise guys!!
Curr946
glad you got it. I had running issues on a touring after fitting a 2.5 and it was the same plug at fault. just couldnt remember the technical name for it
tom325sport
Now it won't crank over!! Bloody thing!
I have new wiring from c191 plug and continuity all good.
Now the engine will NOT crank over! Battery is good, engine lights on the dash are present, I can here a buzz from somewhere in the engine bay - ICV?
When I turn the key to start (position 3) the starter motor clicks and then nothing? It worked yesterday but suddenly nothing. I have power going to the starter motor as well and I can turn the engine at the crank.
Any suggestions please would be most appreciated.
BenHar
Check the battery connections are tight.
Ben
Ben
mark_i
double check the battery voltage...should be more than 12.5 volts.
tom325sport
OK will check all the battery connections and voltages. I did try and start the car with my daily driver by jump starting but it still wouldn't crank over.
I've heard I can bridge pins 11 and 14 of the diagnostic plug to see if it cranks - is this right?
Billwill
tom325sport wrote:OK will check all the battery connections and voltages. I did try and start the car with my daily driver by jump starting but it still wouldn't crank over.
Yes, as Brian Mooore has stated, bridging pins 11 and 14 basically supplies +12 volts to the solenoid exactly as if it was coming from the ignition switch. If it now starts OK then you either have a bad ignition switch which is quite common or the wire coming from the ignition switch to the solenoid has a bad connection somewhere.
tom325sport
OK thanks very much. Will try bridging 11 and 14 and see if it cranks!
What if it doesn't crank? Faulty starter motor?
