Cool running
Ellwood
Post Mon Nov 14, 2011 11:57 am
Hi
Have just bought a 1990 325i se. Everything's great, but have one little concern.
When driving the car seems to "run cool". The needle on the temp guage is between a quarter and the halfway point (closer to the quarter point). If I leave the car to idle then it sits at the halfway point and doesn't move.
The heater blows hot air, no problems and there's no mayo or gunk in the coolant.
Any ideas? I was thinking maybe an airlock?
Be grateful for your thoughts/experience.
Nik
mrLEE30
Post Mon Nov 14, 2011 1:12 pm
It is doing exactly as it should, the middle area of e30 guage only covers a few degrees, so anywhere in that region is fine. Quite normal to drop when moving and rise slightly when stationary (you can see how little change is required to move the guage, next time stationary put heater to fully hot and fan to full, the guage will drop a bit).
Keep eye on coolant level, and enjoy your car.
kolee
Post Mon Nov 14, 2011 1:15 pm
Mines exactly the same, sits at around 10:30 when on open roads, only ever goes up to the 12'oclock position when stood in trafic. All is good!
mrLEE30
Post Mon Nov 14, 2011 2:40 pm
Ps for a reference I live in a country where we see 50C and above in summer, my 325 does same.
Post Mon Nov 14, 2011 3:12 pm
Only an 80 degree thermostat in M20s, so it should run at the cool end of the scale. Perfectly normal.
Ellwood
Post Mon Nov 14, 2011 4:00 pm
Thanks guys - fantastic news!
Really appreciate your comments.
Nik
