Diesel conversion
greg124
Post Sat Nov 12, 2011 7:32 pm
Our lass is moaning again about how much she spends on fuel going to work and back, and asking me what I think about various rather expensive horrible modern cars.
Would it be feasible to drop a diesel engine into an M10 engined automatic chromie?
Schadenfreude - the German's haven't got a word for that.
Sanchez
Post Sat Nov 12, 2011 7:35 pm
Anythings possible, depends how much time and money you have.
But im no expert and its not something that you here lots of in the engine swap world.
Kos
Post Sat Nov 12, 2011 7:44 pm
pug 306 turbo D
lots MPG and they go on for ages and will be cheaper to buy than any sort of derv engine swap you are considering
monkey
Post Sat Nov 12, 2011 7:48 pm
i have thought about a pug 306 td engine with a ldv pilot gearbox into an e30
greg124
Post Sat Nov 12, 2011 8:01 pm
only proviso is it has to be automatic, as she only has a licence for an auto.
What would be really great is if we could find something that runs on veggie oil, and I think that is down to how much lubricity the injector pump needs.
Time to air your ideas for a green powered E30
Post Sat Nov 12, 2011 8:27 pm
LPG what you already have.
Easier and cheaper than a conversion to Diesel if you DIY.
**BANNED**
Post Sat Nov 12, 2011 8:30 pm
greg124 wrote:only proviso is it has to be automatic, as she only has a licence for an auto.
A burd that will only drive an auto...at least 'er indoors will only drive on roads that she has driven on before,in a manual... :o:
Youth is wasted on the young.
greg124
Post Sat Nov 12, 2011 8:34 pm
Can you LPG a carb?
(she did titter at being referred to as a 'bird')
johnl320
Post Sat Nov 12, 2011 8:36 pm
Yes you can
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Nov 12, 2011 9:11 pm
If you convert to diesel, aside from changing the engine, gearbox, prop, diff, exhaust, loom and ECU, you'll need to replace all the fuel lines under the car and the tank. This will mean dropping the back axle to the floor to get to the fuel lines as well, so in effect stripping the car to a bare shell and the rebuilding from scratch.
A hell of a lot easier just to stick an LPG mixer into the engine bay...
Post Sat Nov 12, 2011 9:15 pm
greg124 wrote:Can you LPG a carb?
The cheaper LPG conversions are actually converting injected cars to carb.
LPG only needs a very simple carb - no float chamber and nothing needed to try to make the fuel into a gas.
Mikey_Boy
Post Sat Nov 12, 2011 9:39 pm
LPG is a great idea and works so long as the tax rebates on the fuel exist...
Diesel conversion is v v tricky - easier to buy a shagger diesel for your other half, but if you do, PLEASE don't run it on veggie oil or knackered fuel pumps and blocked injectors await you... 8O
greg124
Post Sun Nov 13, 2011 11:22 am
Thanks for the advice guys.
I've just done a quick calculation on fuel cost, and at the current price of £0.78/litre for LPG assuming slightly worse mpg, say 30, that works out at 11.8p/mile. Diesel is currently £1.40/litre, so any diesel conversion would have to yield better than 54mpg to beat LPG on cost.
I seem to remember reading recently on the zone that you can do an LPG conversion for about £300 with judicious use of the Electric-Bay.
Any advice on what's needed, or is there a Wiki?
Grrrmachine
Post Sun Nov 13, 2011 12:40 pm
No Wiki as yet, but search the Tech forum; all the info is there, I just haven't had the chance to dig it all out yet...
Morat
Post Sun Nov 13, 2011 12:53 pm
Straight Vegetable Oil (SVO) isn't a great idea, especially in winter. There are genuine bio-diesel suppliers who will sell you recycled (veggie/other) oil that has been properly processed to give you a fuel that meets the manufacturer specs for Diesel engines - but they are not exactly common.
My wife and I ran a Golf Mk3 1.9 non-turbo diesel on that stuff for a couple of years on and off with no ill effects.
Also, running SVO without paying duty can get you into trouble because the plod can smell the exhaust (smells of chips) and ask you to produce your fuel receipt. If it's an Asda receipt for 40L of cooking oil you've got some explaining to do! :)
