OBC backlight bulb link
Brian28
A while back somebody had posted a link of where to order new OBC backlight bulbs online, but can't find it now. Anybody have the link please? Or any bulbs they want to sell?
For sale - E30 320i racer project - sold.
Grrrmachine
- E30 Zone Wiki / Team Member
It's not what you asked for, but this tells you how to convert to LEDS so that you never have to change the bulbs again:
http://newling.no-ip.com/rep/bordcomput ... licht.html
Last Tuesday to be exact.Brian28 wrote:A while back somebody had posted a link of where to order new OBC backlight bulbs online,
LED conversion is both pointless and gives inferior performance, for the reasons I give in this link: http://www.e30zone.net/modules.php?name ... hlight=obc
Brian28
Thanks, googled that part number, direct link should anybody else need it
http://cpc.farnell.com/sli-ebt/715-004/ ... dp/SC00338
Edit - Ouch. £5.95 handling charge on a two quid part
Grrrmachine
Sure that's the right link Brian? I can't see any mention of LEDs in there
Sanchez
I did the LED conversion and for me its perfect.
Yes it doesnt dim when headlights are on but you do get a slight dim with the headlight switch is twisted to dim the interior lighting.
You're quite correct! It's not the link I thought it was.Grrrmachine wrote:Sure that's the right link Brian? I can't see any mention of LEDs in there
The problem with LEDs is that their light is highly directional, so the lighting is uneven, and they don't dim when the exterior lights are turned on.
The bulbs I have suggested have a rated life that equates to around half a million miles, so most of us shouldn't be doing the job twice.
LEDs would only be worthwhile if you modified the OBC so that the time was displayed with the ignition off.
CPC's carriage charge reduces with the size of the order, and becomes zero after £40, IIRC. Loads of stuff in their catalogue (it's nearly 3" thick!), so it's not difficult to get free P&P.
Sanchez
Bulbs are great if you get the ones like Brian and they last. I can see my display day and night and ive got the led's in the right place.
These days no 2 e30's are the same and its nice to be different.
Royalratch
I've gone through a brand new Light Bar in under a year. They;re just fragile and shit and prone to blowing, like any filament bulb.Brianmoooore wrote:The bulbs I have suggested have a rated life that equates to around half a million miles, so most of us shouldn't be doing the job twice.
And before you say my cars electrics are fooked, they aren't, because I haven;'t blown a single dash bulb in over 5 years - always the goodamn OBC!
Thanks for the link tho Brian!
The two bulbs in the light bar are rated at 5 volts, and are series connected, so they should be fed by a maximum of 10 volts.Royalratch wrote:I've gone through a brand new Light Bar in under a year.
I've no idea what drops the supply voltage to this level inside the OBC, or whether it can possibly fail, but a light bar that was receiving full battery voltage would have a short life.
It might be an interesting exercise to measure the supply voltage to the bulbs in your OBC.
Royalratch
Which pin is that on the green connector?
And why would BMW do such a seemingly illogical thing...?
No good measuring the voltage on the green connector - that will be full battery voltage.
The voltage drop is done internally in the OBC, and to measure the voltage at the bulbs, you'd have to attach a couple of very thin wires to the light bar itself, slide the bar into place with the wires leading out of the side of the OBC, past the end of the bar, connect the OBC up to the green plug, then measure the voltage on the two wires with the ignition on.
I've no idea why a 10 volt bulb was chosen, but I'm sure it would make sense if I could see a full wiring diagram of the unit.
Royalratch
Why not use 12V bulbs - excess capacity would mean it would live longer...?
12 volt bulbs would live longer - and considerably dimmer. The 500,000 mile estimated life of the 2 x 5 volts ones is good enough for me.
Royalratch
Sorry Brian but that made me chuckle.
OBC bulbs lasting 500,000 miles...? They don;t last 500!
If it's failed that quickly, march it back to BMW. Two year warranty on parts. If the next one fails, then your OBC is probably killing them.Royalratch wrote:Sorry Brian but that made me chuckle.
The bulbs in my link are of the same current rating and of very similar brightness to the genuine BMW article, so I expect the rated life of the OE bulbs isn't too different to mine.
Actually, the 500,000 mile life is the L/D 50 rating - the time after which half of individual bulbs should have failed, so they're not quite as good as I originally suggested. I've still not changed one twice though.
