Steering rack
DazzyA
Post Sat Nov 12, 2005 7:05 pm
I need a new steering rack, amongst many other things, so was thinking of getting a manual instead of power for a 325i cab, would a manual be compatible with existing? and am I being silly not paying the extra for the power.
cheers.
Pass me the spanner
smithy318i
Post Sat Nov 12, 2005 7:25 pm
yes. you are being Very silly.
stappin
Post Sat Nov 12, 2005 7:30 pm
how much is a Z3 rack they are the same arent they? Just with a better ratio anyone done this?
smithy318i
Post Sat Nov 12, 2005 7:40 pm
I thought it was the E36 rack !
eko
Old timer
Post Sat Nov 12, 2005 7:52 pm
this may be of use :)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ename=ADME%
i was going to bid on this the other day,but ended up getting one local.
Post Sat Nov 12, 2005 8:21 pm
stappin wrote:how much is a Z3 rack they are the same arent they? Just with a better ratio anyone done this?
AFAIK, the Z3 rack has the same ratio as the E36. It has less turns lock to lock because the lock is restricted on the Z3, presumably because of tyre rubbing problems.
DazzyA
Post Sat Nov 12, 2005 10:08 pm
eko, thanks mate will bid on that.
would a z3/e36 fit anyone?
Pass me the spanner
stappin
Thanks for clearing that up Brian I must admit I'd heard o hear a while ago about the ratio thing but you seem pretty clued up so i'll trust ya :wink:
So do this mean that the Z3 has a poor turning circle when compared to an E36 if the lock is restricted? :?
Post Sat Nov 12, 2005 10:24 pm
Don't take it as gospel. I've never set eyes on a Z3 rack. Just repeating what I've read elsewhere.
DazzyA
Post Mon Nov 14, 2005 9:44 pm
How difficult are these to change, do you require any specialist tools, still waiting for my manual!!!
will a E36 rack fit?
Pass me the spanner
eko
Old timer
Post Mon Nov 14, 2005 9:48 pm
dont know about E36 rack,but standard one easy enough to fit.
did mine last week and it took about 1.5 hrs to do.
no special tools needed.
DazzyA
Post Mon Nov 14, 2005 10:06 pm
thats not too bad, haven't got much ground clearance would i need ramps, axel stands?
Pass me the spanner
