I had a similar problem with an E34 535iSE; strangely enough, fitting the standard BMW FPR made it over-fuel, while reverting back to the Mangoletsi adjustable one made it better.
15mpg
I'd try a lower fuel pressure regulator, 3 bar perhaps.
- **BANNED**
As it's an Emerald ECU
maybe it's time to have a telephone converstaion with Mr Walker! Somewhat cheaper than driving into darkest Norfolk
and may just extract a nugget that will help the rest of us to help you.....
My gut feeling is that the problem is a sensor not being read by the ECU,or that the ECU is set up incorrectly to chuck far to much fuel at the thing.
What sort of emmisions have been recorded at MoT time?
Youth is wasted on the young.
- Homo Hair
Could be the MAF..
hongkongfuey
- Mad-tango-geezer
Its not a plastic job, its a metal tube with sensor
with cars like mine,
suchy
- True Zone Relic
Who bloody knows what's been done!! Fixing someone elses f*ckup (or trying to work out what is wrong) is always fun! Do you think a photo would help here at all?hongkongfuey wrote:If i remember rightly, this has a non standard, tps, i think it is a 5 pin one, its deffo not standard, it has maf too, also the off has a filter on it, and the throttle bellows has been blocked off, a photo would help here,
suchy
- True Zone Relic
Tried lowering the fuel pressure when it was last on the rollers and it leaned out quite drastically so need to fix problem before changing the fuel pressure regulator. What power will a standard one run to. I'm guessing north of 200bhp is fine on standard?Speedtouch wrote:I'd try a lower fuel pressure regulator, 3 bar perhaps.
suchy
- True Zone Relic
Rob is it actually a proper MAF conversion? The paperwork from Bexley state an 'air mass meter conversion' is this the same thing?hongkongfuey wrote:Its not a plastic job, its a metal tube with sensor
Anyone have a picture of a proper MAF conversion?
- **BANNED**
M50 with standard MAF;
suchy
- True Zone Relic
I'll go take pics of mine- looks nothing like either of them
(I've never rated Bexley's work on mine)
- **BANNED**
In simple terms that I can understand,a MAF is a tube with a wire sensor mounted in it,on my M50 pictured above,the tube is plastic and the sensor mounts within.Your's is the same idea,but it's a steel tube.
Now the AFM that is standard on E30 is a similar tube,but has a mechanical flap mounted in it that runs an arm over a track to signal the airflow,it is a combination of the flap and the signaling system that makes the unrestricted design of the MAF so appealing to tuners/modifiers.
Now given that you have checked and are happy with the only other two gadgets that feed information into the ECU(blue sensor and TPS)that leaves only that MAF unit and the ECU it's self as suspects....
So either talking to Bexley or Mr Walker would seem to be your best options now.
Another possibility would be to revert to standard,at least as far as ECU and engine loom are concerned,and see if Gunni can help you with a purpose designed chip/mapping session.Gunni may be able to adjust the Emerald unit,but you will need to approach him and seek his advice.
Quaser
Bexleys dont know how to map cars - period!!
many of the older zoners know the issues that i have had with them - 2.7 converstion, maf conversion, and unichip.
car was always pinking 3k upwards - so i took it to castle coombe motors and had Paul Sheppard have a go at it - He advised that the mapping was very crude - rather then map every block, they would map at certain points (500k intervals) and average out in between.
Like your car, mine was running at 100% duty cycle so a fuel pressure regulator was fitted and m30 injectors (cant use the m50 or m52 ones as they have the wrong spray pattern and will cause bore wash!!)
the car was much better but when i left it for a while, i found it was bad around town. Im going to go to gunni and get the original ecu remapped for the car. Ecu's like unichip and emerald are good for certain conditions, but outside of those conditions (as when car was mapped) driveablility is affected.
Q
Q
suchy
- True Zone Relic
I've never rated Bexley's after seeing their work on mine hence not taking it back to them- didn't back then, wouldn't now!! Mine also had the conversion and Unichip + a vernier pulley. For all I know they dialed that in wrong also. Engine has a cam in it also (I don't know the specs) but has loads of grunt low-down and runs out of steam at 5K which is not what I'd expect with a higher lift cam!! Cam doesn't look worn at all but without knowing the specs and actually measuring the duration and lift, here-say is worthless on that.Quaser wrote:Bexleys dont know how to map cars - period!!
Q
But yeah we're not the only ones to have spoken bad about Bexley's in the past.
suchy
- True Zone Relic
[quote="daimlerman"]
quote]
Are these the only things that the engine is mapped from?
Blue sensor, TPS, MAF? And then mapped from the info these provide to the ECU?
I believe it's mapped 'correctly' (as best as it can in current setup) but I've always suspected to overcome a problem.
What faults can be had from dialing a cam in slightly out or is this done to change the behaviour of a cam with a vernier pulley? Any benefits??
quote]
- Homo Hair
Paul Sheppard is much closer to you isn't he Suchy...?
The power behaviour is VERY odd considering you say it's an 'uprated' jobbie
- **BANNED**
Cam timing is vital to the final result,I'd forgotten about the vernier pulley...your initial power fiqures of 190bhp(ish) would hint at cam upgrade,but my 2.7 responded in a similar way with a stock 325 cam and a BHP fiqure of about 174...swapped to an ex E21 323 cam and the grunt comes in a little higher at 2500rpm,but it's still pulling when the rev limiter cuts in.
When Gunni played with mine this spring,he started with a power run that showed 169bhp,and finished with 173bhp.The fiqures are just that,the difference in in the way it drives,26/27mpg before,30/31mpg after.
Different dyno's give different numbers,tank full to tank full is perhaps a bit more meaningfull!
Why don't you try fixing the split hose before condemning the rest of the setup? Vacuum leaks can cause all manner of havoc with injection, because the ECU gets confused.
suchy
- True Zone Relic
He's at Castle Combe yeah? Which is 2hrs 100milesJhonno wrote:Paul Sheppard is much closer to you isn't he Suchy...?
Isn't Gunni Oxford? That's 90mins 80miles which is the same roughly as A-Tech (I have Fowlers number also)
All three of these know E30's where as Dave Walker knows Emerald (and does motorsport apps) so is also in the running but is twice the distance away.
Yeah output/behaviour is odd considering the parts fitted!! Should behave differently, be quicker, drink less...
suchy
- True Zone Relic
Only noticed that when I took the pics earlierSpeedtouch wrote:Why don't you try fixing the split hose before condemning the rest of the setup? Vacuum leaks can cause all manner of havoc with injection, because the ECU gets confused.
suchy
- True Zone Relic
I'm not playing the "I've got more horsepower than you" game btw!! 200bhp would be great but drinking the proper amout of fuel would be greater!! This is all about sub-200bhp doing 15-20mpg with 100% rate cycle @ 4Bar fuel economy!daimlerman wrote:26/27mpg before,30/31mpg after.
- **BANNED**
- Homo Hair
Me finks you're gonna have to bite the bullet Suchy! (After taping that pipe up..)
suchy
- True Zone Relic
Yup! I think this one may hurt...Jhonno wrote:Me finks you're gonna have to bite the bullet Suchy! (After taping that pipe up..)
Oh well I should be used to it forking out for 15mpg at UK prices
- **BANNED**
Bend over and lube up?
Offer to do the piccies for the fixer's website?
parkin10
i know this is a modified engine with the maf on it and so on
but in the third pic why does the icv have a pipe that goes to that little air filter ?
surely this allows unmetered air to enter the engine and the need to push the injectors to there limits to get the fueling right
would it not run better with the icv connected to the intake boot as stock?
and then remap it at that
Darwinism at it's best,
I'm sorry but I would remove all that lot and fit another BMW engine loom, standard ECU and correct inlet,
back in standard form with your wild cam is should be still fairly lively ?
why does the ICV take air straight from the K&N ?
ShepsEvo3
- Master of go faster
Q, I didn't know you were still getting grief with your car? I remember it was a pain to get right and was tempramental. As discussed, the old DOS type Unichip isn't really designed for the MAF conversion, but the later Unichip Q is. I've done a few standard 325i and 325i with 2.7ltr conversion with the Unichip Q and removing the AFM with great success.Quaser wrote:Bexleys dont know how to map cars - period!!
Q
To the original poster.. M30 injectors are needed as well as a hike in fuel pressure. Seems that the 325i injectors are only good for around 185/190bhp. More can be had, but you start running a tad on the lean side.
Nothing wrong with the Emerald, I actually like this ECU and is easy to map. The tube looks like it's just that.. a tube inplace of the AFM and has an intake temp sensor fitted. Doesn't look like a MAF atall.
To me it sounds like something isn't set right, or it's just mapped wrong - basics aside.
Hope you get it sorted.
Paul.
www.sabre-tuning.co.uk
suchy
- True Zone Relic
I have absolutely no idea- that was a Bexley special! Anyone shed any light on it?parkin10 wrote:[
suchy
- True Zone Relic
You mean where there is a stub sticking out of the boot? It has a blanking thing in it.e30topless wrote:why does the ICV take air straight from the K&N ?
suchy
- True Zone Relic
[quote="ShepsEvo3.]
Nothing wrong with the Emerald, I actually like this ECU and is easy to map. The tube looks like it's just that.. a tube inplace of the AFM and has an intake temp sensor fitted. Doesn't look like a MAF atall.[/quote]
It's fitted with some variable fuel presure regulator at present, is there a better replacement (another car?).
Wow only 185/190bhp from standard injectors- BMW didn't allow much tolerance in them then!! M30 injectors should see the duty rate come down a bit then??
When Bexley's did the original conversion they just stated an "air mass meter conversion" so who knows what it is or if it even works
HairyScreech
ok, im with sheps, thats not a maf.
this thing must have been mapped alpha n and intake air temperature correction used.
i assume you get a smoothly varying resistance from the throttle position sensor?
take that senor out of the "maf" and get a picture up and part number.
oh and i see absolutely no reason the multi hole m50/52 injectors would cause bore wash provided they are mapped in? what makes you say that?
e301988325i
This looks like a secondary bodge to me, the car should have a 'T' ICV fitted, but in fact has an 'L' version, although TBH looking at your metal intake pipe i don't think this will cause any issues.suchy wrote:You mean where there is a stub sticking out of the boot? It has a blanking thing in it.e30topless wrote:why does the ICV take air straight from the K&N ?
Please look at your TPS and let us know if it is identical to this, which is a switchable auto TPS with variable resistance?
or this
http://www.google.co.uk/imgres?q=e30+TP ... 29,r:2,s:0
I said:
e30topless said:
lock the wife in there
Any pics of the FPR - is it this type?
4 bar sounds like overkill for this engine, and may be contributing to your rich running and poor mpg. I have a spare standard BMW 325i 3 bar one, if you're interested, for a tenner posted...
Part numbers are Pierburg 7.21 197.10 /1 711 543.9
http://www.ms-motor-service.com/ximages ... en_web.pdf
http://www.realoem.com/bmw/showparts.do ... g=13&fg=15
Interestingly, this is also used on the M30B35, so should easily be adequate for a tweaked M20B25!
hongkongfuey
- Mad-tango-geezer
I thought the 2.7 alpina had normal 2.5 injectors?
ShepsEvo3
There is no MAF present in those pictures. The IACV has a small K&N breather type filter to stop particals getting into the IACV and the engine. So as there is no MAF, there is nothing to "meter" the air, so the fact it is unmetered doesn't matter. If there is a MAP sensor fitted to the inlet manifold, then obviously this would be affected by how much air is being let into the engine by the IACV, so in effect will be monitored.
That however looks like it is mapped Alpha N style. Nothing wrong with that unless it was turbo charged.
Make sure the TPS is working properly.
