cant get m20 inlet manifold back on
retroboyo
Post Thu Nov 10, 2011 1:57 pm
As per subject.
It just wont go on!!!
The supporting pillar stops it getting low enough to slide on. Take the pillar off and no problem.
Any tips please
gooner1
Out humping Reindeer
Post Thu Nov 10, 2011 2:13 pm
boyo, do you mean part No 11 below?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
If so, cable tie the two springs, part 12 as tight as you can,
then with the tube and springs in place you will find it easier.
Cut and remove ties after. Would be good to re new the washers
too.
retroboyo
Post Thu Nov 10, 2011 2:17 pm
Thanks gooner, thats the one
**BANNED**
Post Thu Nov 10, 2011 2:18 pm
too.
In English;
Use two cable ties to compress the spring,re-fit the breather tube and springs with new O rings at each end.
Bolt the manifold home,then cut the cable ties and guide the breather pipe into place.
Youth is wasted on the young.
gooner1
Post Thu Nov 10, 2011 2:24 pm
retroboyo wrote:Thanks gooner, thats the one
Well, seems like someone understood me, Malcolm. :flipbird:
No problem, boyo.
