88 320 convertible fuel vent?
lamby
i have noticed a smell of fuel from around the fuel filter lately but can,t see why,all pipes in that area are dry but i have noticed a pipe coming down with an open end.is this a vent pipe and would it smell?car does sometimes take a while to start(indicating a fuel pressure leak)but can,t see any evidence.pump top and hose under seat are dry and fume free.only smell at pass side drivers side nothing. car is running fine bit thirsty but its local journeys so.................
Kedge
Yea that sounds like the vent, it routes all the way from the catch bottle up in the drivers side rear arch.
You sure there's no sign of any leaks around the tank seem?
lamby
none that i can see but then again it never has much fuel in it as its only used for the school run.the tank looks ok but then the fumes could be coming out without a leak when car is running?can the tank be pressure tested
- **BANNED**
Pipe on the n/s should run up the underside along side feed and return to terminate either at a carbon cannister mounted on the n/s/f inner wing or in an open rubber tube tucked into the n/s/f suspension turret.
Large breather from the top of the tank on the driver's side runs through the o/s/r inner wing to the expansion tank high under the o/s/r wing by the filler.I have found leaks from this pipe at the tank end can be cured by carefully trimming the last inch off the pipe and re-fitting.
However,if the smell is on the n/s,I would be searching for a pinhole in the steel feed/returns,please do not use a naked flame.....
Youth is wasted on the young.
lamby
naked flame no she left me years ago
have looked at them are they steel where not visible or just where you can see,smell is def at filter area.if the filter is clogged would that cause it to vent,i.e pump is straining.i will run it later to see if its just on start up or all the time.thanks so far,now where,s them matches...........
Kedge
Never seen set ups like that, all my e30s have vented on the n/s front corner of the tank, that pipe the either runs over the top of the tank and up to the expansion tank on the o/s/r arch, or is clipped directly to the cars body as per my chromie which currently has the tank out.daimlerman wrote:Pipe on the n/s should run up the underside along side feed and return to terminate either at a carbon cannister mounted on the n/s/f inner wing or in an open rubber tube tucked into the n/s/f suspension turret.
