Rear Top Mounts
turkeysneck
I'm changing the rear shocks for some uprated ones and I need to change the top mounts, I presume for uprated ones. I think I read somewhere that the top mounts from the E46 are direct replacements, is this correct ? If it is which E46 model do I need to get.
E46 cabriolet.
Make sure you fit the required steel washers under the mounts, on the top of the damper rod, or your new mounts will last about a week!
turkeysneck
Is this a standard washer on the E30 or do I need to get it from the E46.
Grrrmachine
- E30 Zone Wiki / Team Member
