coolant issues please help
LLamaFarm
Post Tue Nov 08, 2011 5:11 pm
i did a search but it didnt really answer anything for me so hopefuly someone can help :)
my 325 m20 runs at 3/4 hot so theres an issue somewhere that ive been trying to find, the heaters blow hot air so i assume the water pump is circulating, the bottom of radiator is cold, the top is warm, so is it the thermostat and the hoses are just hot from the water in engine/surrounding area, or is the radiator blocked? looks relitivly new the rad does so im suspecting the stat but the warm hoses have got be confused
thanks
mattycoops43
Post Tue Nov 08, 2011 5:35 pm
Faulty gauge? Is it actually too hot? does it smell hot? All sounds normal to me apart from the gauge.
1990 325i se "weinrot"-How did they know?
LLamaFarm
Post Tue Nov 08, 2011 6:01 pm
the radiator should be at least warm though not stone cold?
mattycoops43
Post Tue Nov 08, 2011 7:18 pm
You said the bottom is cold, the top is warm.
LLamaFarm
Post Wed Nov 09, 2011 10:29 am
yea it is, the top rail is hot and the bottom/most of it is cold is this normal then? the guage never really goes over 3/4 maybe a nats over sometimes, i replaced the guage sensor a while back as it didnt work could i have a crappy sensor?
Post Wed Nov 09, 2011 10:31 am
Check the small brass nut on the back of the cluster (or lack of it) before you get too involved.
Mikey_Boy
Post Wed Nov 09, 2011 12:44 pm
+1 - this sounds like a gauge issue rather than anything really wrong...
LLamaFarm
Post Wed Nov 09, 2011 5:28 pm
thanks for help, i checked the nut and thats ok, maybe its the sensor, i believe its from a 320 and mines a 325 if that makes a difference?
im kinda thinking the thermostat is opening as i commute 17 miles odd and it dont go over 3/4??? it would need to open going that far and have some sort of cooling.
LLamaFarm
Post Thu Nov 10, 2011 5:03 pm
bumpty mcbumpten :)
Post Thu Nov 10, 2011 9:17 pm
Sensors are all the same.
If the gauge reading is stable when the car is up to temp., then IF it is overheating, and not a gauge fault, it can only be a thermostat problem.
Any indication that it is actually overheating when you switch the engine off, such as boiling noises?
LLamaFarm
Post Fri Nov 11, 2011 8:51 am
all looks and sounds pretty normal, ill swap the thermostat tomorrow just in case
Thanks Brian your a legend :)
mrLEE30
Post Fri Nov 11, 2011 9:02 am
You may even find there is no thermostat.
LLamaFarm
Post Thu Nov 17, 2011 1:50 pm
update incase anyone else has same issues,
was the thermostat sticking slightly, still opened in boiling water but when testing against new one didnt open as far, car runs better, on a second note the hose decided to split on the housing and was a bitch to remove so for others doing a search as i didnt find much heres the how too simple way
if its a m20 its simple if you know how, dont need to take inlet off at all either, first obvioulsy all pipes off and remove the temp guage sensor, 2nd loosen the bolts holding housing on, 3rd unclip the plastic rail next to the fuel rail should pull off, be gentle though. 4th there are four bolts mounting the metal fuel rail on undo theese and it should lift up enough to enable you to remove the housing. - stupid design imo
eurocar parts do a nice shiney new housing for £30 delivered :)
haynes manual on suggesting removing half the car is all horse crap and shouldnt be followed unless you want to spend all day doing it.
thanks for all the help everyone :)
