Soundproofing
Jozi
Post Sun Oct 30, 2011 12:52 pm
Anyone soundproofed their whole E30? Any advice on what area's to do?
I'll be removing whats left of the existing sound proofing and then painting everything (which seems pointless as it will be covered again :mad: ) before applying new sound proffing.
I looked at Dynamat but it's very expansive! I found this which seems to get good reviews and is considerably cheaper!
Does it make sense to cover the whole floor pan of the car and the bulkhead or is this a waste of time? What about the roof? Inside door panels?
zaust
Zone day release
Post Fri Nov 04, 2011 4:18 pm
If your not worried about weight then use roof tile matt. Very very good for audio installs.
You only need to cover the centre sections of the panels and not in big sections either.the corners you can use very small amounts of expanding foam. but check which one you get as some are corrosive to metal. when your finished do the tap tap test. Hth
M30 Tech 1 Touring on gas.
miniblob
Post Tue Nov 08, 2011 11:37 am
Dunno if I said it on your other thread, but there is someone on the talkaudio forum that sells sound deadening which is a lot cheaper than most and very highly rated!!! Maybe loudboy????
Just ask on there and he'll appear!!!
btw, not tried it and dunno how much it is - just going on what i've read on there!!!
327 Touring with bass!!!
Jozi
Post Tue Nov 08, 2011 1:40 pm
Sorry Zaust missed your post. Roof tile matt? You mean like a felt tipe product? I thought of doing the whole floor but that was before reading you just use it in the centre of panel to stop them resonating.
I found this http://www.caraudiodirect.co.uk/silent- ... -pack.html which I thuoght was reasonable, looking at reviews it's meant to be decent enough as well and a whole lot cheaper than dynamat!
skipunda
Post Tue Nov 08, 2011 1:52 pm
I like that link, Jozi. The price is reasonable too if it does the job to the same standard (or better) as the existing soundproofing.
Chris
Monkey27
Post Tue Nov 08, 2011 2:22 pm
Jozi wrote:Anyone soundproofed their whole E30? Any advice on what area's to do?
I've used Dynamat Superlite on the entire floor plan, does the job quite well though as you said is very expensive. I bought the bulk pack from www.caraudiosecurity.com.
Jozi
Post Tue Nov 08, 2011 6:43 pm
I don't know will 41 sheets do an E30 though, I imagine it would with some left over as well?
I have a post up on talk audio and a closed cell sound proofing was mentioned, any idea what this means? Closed to me sounds like it could trap moisture and promote rust over time?
Monkey27
Post Tue Nov 08, 2011 9:17 pm
Jozi wrote:I don't know will 41 sheets do an E30 though, I imagine it would with some left over as well?
I used 2 and 1\4 of the bulk pack, you to have clean the floor properly otherwise it will trap moisture and start to rust over time and be very thorough about it. If you have any leaks when you have the carpet out make sure solve all these before doing this job i.e. the usual E30 leaks - heater valve, bulk head etc.
I've not come across closed cell sound proofing, will need to look into, if you want a picture of what I did I can post this up.
Jozi
Post Tue Nov 08, 2011 11:47 pm
Picture would be great to give me an idea :thumb: Bit more sound proofing than I though you'd use if you went through 2+ bulk packs! Is it as good as or better than the original sound proofing? No idea about closed cell, it seems to be more of a building product than anything else.
No worries about the floor being clean :D I'm working from a clean slate with my touring, she's got the full works and will be painted inside and out :cool:
Monkey27
Post Wed Nov 09, 2011 9:28 am
Jozi wrote:Picture would be great to give me an idea :thumb: Bit more sound proofing than I though you'd use if you went through 2+ bulk packs! Is it as good as or better than the original sound proofing? No idea about closed cell, it seems to be more of a building product than anything else.
I'll post up it tonight, I think its just as good as the original sound proofing.
Monkey27
Post Wed Nov 09, 2011 7:18 pm
Here you go, i don't have the completed pics but you'll get the idea. I covered the transmission tunnel and the rear seat area. I double checked on how much I used and it was 1 and 3/4 of a bulk pack, sorry for that.
Jozi
Post Wed Nov 09, 2011 11:00 pm
Nice one thanks Monkey for posting the pics. I've a good idea what has to be done looking at that. I'll need to work out how much I need of it :)
Monkey27
Post Thu Nov 10, 2011 9:15 am
Jozi wrote:Nice one thanks Monkey for posting the pics. I've a good idea what has to be done looking at that. I'll need to work out how much I need of it :)
No probs
zaust
Zone day release
Post Sun Nov 13, 2011 5:21 pm
Jozi wrote:Sorry Zaust missed your post. Roof tile matt? You mean like a felt tipe product? I thought of doing the whole floor but that was before reading you just use it in the centre of panel to stop them resonating.
lol no. The stuff that keeps the tiles on your house. Part lead.
Jozi
Post Sun Nov 13, 2011 5:24 pm
That might be a bit over kill :D
xepa
Post Wed Nov 16, 2011 2:20 am
To Monkey27, how effective was the deadening, is there substantial external noise reduction (road noise, wind and engine/tranny noise)?
Monkey27
Post Wed Nov 16, 2011 12:54 pm
xepa wrote:To Monkey27, how effective was the deadening, is there substantial external noise reduction (road noise, wind and engine/tranny noise)?
It works very well, significant reduction in road\wind and tranmission noise. However it will not drown out loud exhaust systems.
It all depends on how and where you apply it. It is recommended to do it on the roof as well, I didn't do this as its all down to what you where you want to reduce the noise in the car.
You can be OTT and do the entire car inc boot area front and rear archs but that is over kill lol
1989 E30 325i Sport Auto
2003 E39 530d Sport Auto (Sold)
2012 F10 535i M Sport Auto
