Lee Parkes' E30 Alpina B10.
Post Mon Nov 07, 2011 10:01 pm
What spec is the engine?! (Not read the thread.) That torque figure seems pretty high..
Post Mon Nov 07, 2011 10:10 pm
How much more did he say you could sqeeeeeeeeze out of it???? 8O
leeparkes
Post Mon Nov 07, 2011 10:43 pm
Jhonno wrote:What spec is the engine?! (Not read the thread.) That torque figure seems pretty high..
Alpina B10
Forged custom mahle pistons (high comp)
M5 conrods
Flowed head with hemi combustion chambers
Larger valves
268 degree cam
Remapped ECU
Standard M30's make around 230 lb ft.
Im shocked myself and if it was a mobile rolling road type etc i wouldnt of believed it. It was done at Hi-Tech in Cradley heath who have a good rep and reliable rollers, our very own DanThe has used them with his black chromie.
leeparkes
Post Mon Nov 07, 2011 10:53 pm
Rav335uk wrote:How much more did he say you could sqeeeeeeeeze out of it???? 8O
He has worked on quite a few 80's BMW's including a B10 bi turbo so he is very familar with them, with what ive got he could basically re map it but it would move the power band more up the top end. He did mention that a 6 branch works wonders on these lumps though.
Pento. it ran a 14.2 this year with it running like a bag o shite. :)
Cant believe its pissin it down with rain outside. :cry: I want to let rip in it! :twisted:
Post Mon Nov 07, 2011 10:55 pm
Hmm.. What comp ratio? Std is 221lbft, that's 64lbft (29%!) increase! Still seems a lot, however could be the headwork/cam/comp increase working together. Gareth got quite a high torque figure with his increased comp M30 iirc.
Post Mon Nov 07, 2011 10:56 pm
I take it he does live mapping too then.
Is this the one by the Train station, in the estate, but right at the back??
Cook318IS
Bloody hell! Fair play that man! This would definitely get me worried in my m52 8O
Post Mon Nov 07, 2011 10:57 pm
Nice result! :D
leeparkes
Post Mon Nov 07, 2011 11:01 pm
Jhonno wrote:Hmm.. What comp ratio? Std is 221lbft, that's 64lbft (29%!) increase! Still seems a lot, however could be the headwork/cam/comp increase working together. Gareth got quite a high torque figure with his increased comp M30 iirc.
Im sure it 10. something. standard M30 compression is turbo territory, Gareths made 239lb ft iirc.
Rav, yes its by the train station.
Splondike
Post Mon Nov 07, 2011 11:17 pm
Bet you are chuffed mate, must pull like a train :D
Mark.
Post Mon Nov 07, 2011 11:18 pm
Sounds a nice spec anyway.. Must go well! Potentially shows the restricted breathing of the std lump, and the value of headwork/cam/comp! Congrats.
leeparkes
Post Mon Nov 07, 2011 11:41 pm
Cheers everyone. Methinks im gonna need a longer diff ratio now. :)
E30SPORTMAD
Post Mon Nov 07, 2011 11:50 pm
Happy days Lee am sure that is a very good going E30 now you've got urself going by the figures :D
leeparkes
Post Tue Nov 08, 2011 12:27 am
Cheers,
Jhonno, just found it, comp ratio is 10.6:1.
Just realised too looking for that ^ i picked this lump up on the 6th November 2010. A year ago yesterday. :mad:
sheebie
Post Tue Nov 08, 2011 12:44 am
285 thats epic, well done mate
I'm want an m30 again, miss mine...
zaust
Zone day release
Post Tue Nov 08, 2011 8:06 am
leeparkes wrote:Cheers everyone. Methinks im gonna need a longer diff ratio now. :)
want to put mime on the rollers but my local is evolve and they show far the generously.
Well I'm now thinking 3:25:1 LSD for mine as first is not worth using and 5th is screaming at 130+ so don't know what box you have but my 3:46 lsd will be avalible when sourced.
535 sport box I'm using btw.
M30 Tech 1 Touring on gas.
Post Tue Nov 08, 2011 8:50 am
Since when? Didn't Si take the Alpina to 2 rolling roads inc Evolve and got within a couple of BHP between the 2 results. I also believe most S50's that go on there make under factory power! :?
rob0r
Post Tue Nov 08, 2011 11:25 am
Well done Lee, your car must be brutal!
staley_turbo
Post Tue Nov 08, 2011 12:54 pm
Good power. What diff are you thinking? I have a 3.15 in mine and it's quite good.
leeparkes
Post Tue Nov 08, 2011 4:39 pm
Im using a 535i overdrive box, not sure what ratio to go for yet but i do have a 3.38 crown wheel & pinion at hand.
staley_turbo
Post Tue Nov 08, 2011 4:45 pm
Wish I had that box! What have you got in at the minute? I went from a 3.91 and it made all the difference. With all the torque aswell, almost makes it quicker giving it somthing to pull.
leeparkes
Post Tue Nov 08, 2011 4:54 pm
What box you using? Ive got a 3.64 on now.
rob0r
Post Tue Nov 08, 2011 5:36 pm
staley_turbo wrote:Wish I had that box! What have you got in at the minute? I went from a 3.91 and it made all the difference. With all the torque aswell, almost makes it quicker giving it somthing to pull.
I think I know what you mean. I'm currently using an M10 box with a 3.91 diff, the diff ratio is actually matched to the box, but my standard M30 is making short work of it and I'm through the rev range too quickly. I'm sure making most of the torque available with a longer diff will make it quicker. I'm tempted to drop down to a 3.64.
leeparkes
Post Tue Nov 08, 2011 6:20 pm
Imo a 3.64 is the perfect diff for a standard M30. 1st is just about usable. :)
zaust
Zone day release
Post Tue Nov 08, 2011 6:58 pm
Went up with a few guy's from ur racing. Every single one of them made more power than they even dreamed. one that sticks out in my mind is a import cilica making 286 bhp @ evolve when it is box standered and gets ripped up by a standered 1.6 corsa !!! then the leon cupra r with a chip and de-cat making 291.5 ? then 310bhp Fiesta rst !! come on. I leave this dude standing with out nos. And it's not the drivers belive me.
Think they need a check over.
Post Tue Nov 08, 2011 7:09 pm
zaust wrote:
Jhonno wrote:
zaust wrote: want to put mime on the rollers but my local is evolve and they show far the generously.
Both Simon and me had our E30's on Surrey rolling road and Evolves on the same day and they were a couple of BHP/lbft apart.
That was in 2008 though.
Post Tue Nov 08, 2011 7:13 pm
Forgot you were part of that Barry.. Something must have changed then. Odd.
Post Tue Nov 08, 2011 7:14 pm
F*ck me, that is a blinding result Lee!
Great news that you got to the bottom of the running problem. These old AFM's can be problematic and or poorly adjusted. I had to change the one on the B10 as it was running to rich even when fully adjusted to lean it off.
Good replacement AFM and its spot on now.
BTB six branch next?!
leeparkes
Post Wed Nov 09, 2011 6:15 pm
^Thats what im considering, The itb's from an M5 fit but what about the 6 branch from one?
Just checking before i take the plunge. :)
Post Wed Nov 09, 2011 6:27 pm
ITB's will need to come from the M88 or S38, and the adaptor plate from Germany Lee.
Post Wed Nov 09, 2011 6:44 pm
An M88/S38 six branch has different port flanges with 4 studs per port and as far as i know it wouldn't fit anyway.
Some guy on here with a white M30'd cabrio has a BTB six branch and full system so it wouldn't be a prototype you were getting.
Might even be worth trying a group buy now that there are plenty of M30 E30's on here.
jimbom30cab
Tech 1 freak
Post Wed Nov 09, 2011 7:09 pm
nice job Lee, well worth it in the end, great to see
happy days
leeparkes
Post Wed Nov 09, 2011 7:32 pm
bss325i wrote:An M88/S38 six branch has different port flanges with 4 studs per port and as far as i know it wouldn't fit anyway.
bss325i wrote:Some guy on here with a white M30'd cabrio has a BTB six branch and full system so it wouldn't be a prototype you were getting.
Yes, That would be Martin. iirc it doesnt clear an E36 rack though (which i have) but it did do well on the rollers. 8)
zaust
Zone day release
Post Fri Nov 11, 2011 9:52 am
Ad from a1bmw spent ages getting a 6 branch. He ended with the btb for 800 or more
but he did say it made a huge difference.
staley_turbo
Post Fri Nov 11, 2011 2:08 pm
The m88 six branch has the same port spacing. Cut a new flange out, have it nicely welded and you might save your self a few quid?
