rear window mechs 'Q'
Post Mon Nov 07, 2011 5:39 pm
one of my rear mechs isn't playing ball and won't work i can hear the motor click as if it wants to turn but won't.
i've taken the two screws out that fix the motor to the lifter cable housing but it won't come out,it only comes out about half an inch if that.
how do these come out ?
is there a way of getting at the spool of cable to check if it's rusty or just stuck,
i had hoped to change the motor with one from a front door lifter but that won't come out either :(
i've undone this screw, what's it's function :? bottom left big brass screw
can it be fixed or shall i just write it off ???
tia Mick.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Nov 07, 2011 5:43 pm
I've managed to get the motor off the gearbox on two of those scissor-jack style mechanisms, just by undoing every visible screw and a bit of gentle persuasion.
No idea how to separate the cable version though.
As for repair; I remember reading a post AAAAGES (two years +) ago about stripping these motors, de-rusting the innards and rebuilding, so it can be done. Just no idea where that page went.
