Just changed starter motor, still no turnover! ***FIXED***
jimf
Hi, I just changed my starter motor on my 325i but the engine still won't turn. I'm now thinking it could be a wiring fault. The dash lights up as you would expect but nothing else. I can short out the terminals on the motor which will spin it but no engagement.
Any ideas on what to try next.
e301988325i
There are two different 325 starters for motronic 1.0 and 1.3, I'd start researching there, if the motor is spinning but not catching in the flywheel then that's a likely cause.
I said:
e30topless said:
lock the wife in there
jimf
It won't get as far as spinning from the ignition. It doesnt seem to be getting any signal.
- **BANNED**
Starter signal wire is black/yellow.
Is this car an automatic?
Youth is wasted on the young.
try bridge pins 11 and 14 on the diagnostic plug
Billwill
What terminals are you shorting to spin it without engaging?jimf wrote:Hi, I just changed my starter motor on my 325i but the engine still won't turn. I'm now thinking it could be a wiring fault. The dash lights up as you would expect but nothing else. I can short out the terminals on the motor which will spin it but no engagement.
If you short out the two large terminals then you are bypassing the solenoid....the starter will spin because you have connected +12 volts from the battery direct to the starter armature....it will not engage as you have leaft the solenoid out of the equation.
You should see a small black/yellow wire going to the solenoid...this basicaly carries +12 volts from the ignition switch when you turn the ignition to ON....this activates the solenoid which does two things: Firstly it has a forked arm which the elecromagnet in the solenoid causes to swing outwards and in so doing it moves the drive gear on the stater motor shaft outwrds so as to engage the gear in the flywheel teeth. The second thing it does is make a large electrical contactor which shorts out the two large lugs on the solenoid to supply power to the starter.
You need to see that you are getting that +12 volts on the black/yellow wire when you turn th ignition...if not jumper +12 volts directly onto the black/yellow wire...the solenoid should click and the engine turn over. If it does this...the next step is to trace the black/yellow wire to the ignition switch to find out why there is no voltage on it.
There is also the possibility that you have the black/yellow wire connected to the wrong terminal on the solenoid.
jimf
Well, both starter motors seem to operate correctly. Something in the car is telling the starter not to engage. I can't rule out the flywheel of course but surely i should be getting something on the ignition even if this is the case.
The battery is fully charged.
New thought: The car has this awfull clifford alarm that blips and chirps and I hate it.i'm wondering now is the immobiliser at fault?
e30topless wrote:try bridge pins 11 and 14 on the diagnostic plug
jimf
what does bridging these pins do?
- **BANNED**
Instructs the starter to turn.....
Just uses the engine part of the loom,and proves that the starter will function.
its easy to leave 1 of the big wires off when refitting the new motor where the 13mm nut fits.
jimf
I have both big cables connected correctly and the one smaller one
HairyScreech
if none of the above works try the following.
if its not catching its always possible its a bit out of alignment, im missing a dowl from the gearbox which lines the two up, this results in enough misalignment that the motor can miss the teeth.
try loosening the starter bolts off a couple of turns and see if it engages then.
jimf
I'll do the bridging thing tomorrow and let you know
Sorry about the new thread thing guys, i was doing a bit of googling, was reading a lot about the relay and didn't want to mix this one up, it was just a general query and wasn't looking to start a new thread about this snag, just on the location of the relay!
jimf
Would bridging these pins bypass the imobiliser if that is at fault?
if the immobiliser is connected under the dash then yes it should,
bridging the pins sends a direct signal from the battery to the starter ruling out a starter problem if it works ok,
I can't recall the last time I have had an E30 with a knackered starter motor ? it's usually something else !
jimf
I'm a bit gutted I changed it now as it was a right bugger of a job, ripped my arm to shreds and also strained my neck while i was under the car in the process
jimf
Sould I connect the two pins with a chunky wire then connect the battery or connect the battery first and then stick the wire in?
If the car fires up do i need to remove the wire to stop the starter motor or will it disengage on its own?
Just bridge the two pins with any piece of normal wire with the battery connected, but take care to identify the correct two pins.
Just make sure the car is out of gear, and, if you don't want it to start, make sure the ignition is off
jimf
OK, so this is what i have tried so far today.
Bridged pin 11 & 14 and starter spun with no engagement. I tried this with with ignition on and off.
I put a voltmeter on the big connector of the motor and it read 12v.
Then attached voltmeter to the small connector, it read 0v with the turn of the key but read 12v with 11 & 14 bridged. Starter spun but no engagement again.
jimf
I'm wondering if there are two seperate faults here where the ignition wiring under the dash may be faulty AND the starter not connecting with the flywheel.
I want to get it to the point where I can at least get the starter to spin on the key before having to take the motor off again.
The new starter on the car if from a slightly later model, so as E301988325i originaly said it could be the wrong motor.
Edit, just checked numbers on realOEM and they match up ok.
- **BANNED**
Working on the basis that you have a fully charged battery....
Either the starter pinion is not running up the starter shaft to engage the flywheel,or there is nothing on the fly for it to engage to.
Now an engine stops spinning at a similar point each time,so flywheel teeth get worn in just the one spot where the starter engages.I would try turning the engine a quarter turn by hand using the front pulley 22mm nut,then see if the starter engages on a fresh bit of flywheel,if it does,I'll put money on your fly being worn.If there is no change,then the starter is suspect,either faulty or perhaps not properly aliegned as mentioned above.
As I wrote yesterday,starter signal wire is black/yellow,there is a connector behind the glovebox that alarm cowboys use to interupt this wire.....
jimf
I tried turning the enging a bit but the starter still just spins, however, I have discovered a loose black/yellow wire that has obviously been tampered with in the past under the steering column. I can't work out where it is meant to go though. It has a white plastic plug on the end, it looks like the female end of a spade terminal but can't for the life of me find the male end.
- **BANNED**
jimf
Me or the car?! lol
I know, you mentioned that wire at the start of the thread but i thought you were talking about the small wire to the starter. didn't realise you meant under the dash! Sorry
Ok so now i have found that wire but where does it plug into!
Billwill
You should have a black/yellow wire going from ignition switch to the solenoid. This is the one that energises the solenoid. I presume this black/green wire is where you measured +12 volts when you jumpered pin 11 and 14 as you stated above.
Are you sure that this black/green wire is connected to the correct post on the solenoid?
Reason I ask this is that normally....but your car may be different....there is also another wire going to the solenoid namely a black/green wire. This wire goes to the unloader relays K5 and/or K7...but motor will turn over if it is not connected.So there should be two small posts on the solenoid.
So.....have a good look at your solenoid...are you sure there is not another small post...clip-on or screw type that could be the correct position for the black/yellow wire?
Is there not a black/green wire hanging around somewhere near the solenoid...although the car will start without it connected.
jimf
Definately not a black/green wire anywhere. The small wire to the solenoid is just black. The original starter only had one small post next to the big one. The new one actually does have two small posts, an upper one and one underneath the big one. I have it connected to the upper one, i actually did try it on the lower one too but with no effect.
I hope that it the correct one otherwise this could be a bit embarrassing!
The only black/yellow wire i can find is under the steering column and it is loose right now until i can find out where it has come from.
Sounds like you might have found the end that connects to the ignition switch.
The wire from this is plain black.
Billwill
OK try moving your black wire to the other post and try connecting pin 11 to 14 again as Brian suggested...maybe it will turn over now and then you can trace why you are not getting power onto that small wire when turning the ignition key.jimf wrote:Definately not a black/green wire anywhere. The small wire to the solenoid is just black. The original starter only had one small post next to the big one. The new one actually does have two small posts, an upper one and one underneath the big one. I have it connected to the upper one, i actually did try it on the lower one too but with no effect.
My circuit diagrams definitely shows the black.yellow wire must connect to the ignition switch..pin 50? . It probably changes colour to black once it has gone through the large connector inside the engine bay.
The 'black' on the smaller solenoid wires is just the outer sheath, not the real colour of the wires. Turn back the rubber sleeve at the terminal end.
Starter signal is black/yellow all the way (on a manual) until it changes to black at the steering column plug/socket.
jimf
Well, a HUGE thankyou you to everyones help with this snag.
Thankfully it is not the starter or the flywheel at fault. By my own mistake I had the starter wire on the wrong terminal
Swapping that over and bridging 11 & 14 got the engine started
Then under the dash I followed the black wire on the ignition terminal and traced it to the back of the big wiring block under the steering column where I plugged the loose black/yellow wire in.
All good now and just need to put everything back together.
So it looks like the starter was fine all along and the wiring under the dash was slowly making its way loose. I never would have managed that without all your suggestions so thanks again. I'm delighted to say the least.
