VDO Oil temperature gauge problems
appletree
Post Thu Nov 03, 2011 8:21 pm
So i fitted a set of vdo gauges before going supercharged and the oil temp gauge always read 130C at normal running and then rise up to say 135C after abit of a hoon which a 5C rise seemed ok,
I always though that it seemed abit high but as the gauge is scaled 60 - 130 -170 ( see link) and the needle was sitting pritty much bang on the 130 mark and seeing as it seemed to the middle of the gauge i didnt question it.
http://www.ebay.co.uk/itm/VDO-oil-tempe ... 0632089322
Anyway after reading the other day the M42 is supposed to run at around 80C i though id see if my gauge was correct and guess what?? its miles out...
using a laser temp gun the filter housing it was at 80C and 85 ish after a long drive so i'm happy at that. But question is why if the engine is ment to run around 80C are all the oil gauges scaled to 150/170/200C???
The gauges came from a 2ltr N/A Audi 80 so not too different engine.
Does anyone have any idea why the gauges are scaled as they are??
lastly can anyone suggest which sender i should have as i can only guess ive got the wrong sender to make the gauge read 50C out :roll:
penton08
Post Thu Nov 03, 2011 8:35 pm
My VDO oil temp gauge has the same scale as yours, Mine has a blue sender. Afaik there are other colours that will cause wrong readings if paired up with the wrong gauge. I use mine for diff oil temp and i have never seen my gauge above 80 degrees.
appletree
Post Thu Nov 03, 2011 9:30 pm
Thanks mine is a black topped one which I think is 0-120 and I've seen a few white topped ones but notvsure what range they are. Is yours acurate?? :D
Post Thu Nov 03, 2011 10:38 pm
Im using an S50 oil temp sender, but its been that long since I drove the car I really cant remember where it reads :(
appletree
Post Fri Nov 04, 2011 5:30 am
With vdo gauges Dan? Is does it fit in the threads in the oil filter housing?
Post Fri Nov 04, 2011 7:50 am
Well its an S50 filter housing so no problems there :D
I have the audi three gauge setup
