ht leads.... best ones to get?
mineralblue
Rocking Horse Poo
Post Wed Nov 02, 2011 12:42 pm
Afternoon all, I am replacing my HT leads next week and just wanted some pointers as to if there are any other ones to go for other than original BM ones that are as good/better?
Would the only difference be in life span?
Thanks in advance.
MattTheHat325
Post Wed Nov 02, 2011 2:54 pm
Genuine BMW ones are regarded as the way to go around here mate, aftermarket ones show no real advantage on e30's and the original ones seem to last the best part of 20 years before they start to fester!
Unless you have some kind of colour scheme going on under the bonnet and you want red/blue leads? Other than that, OEM bud.
greg124
Post Wed Nov 02, 2011 9:07 pm
Just replaced mine with an OEM set. £75 inc VAT from German, Swedish & French. Only put them on today, so can't report on performance yet.
They were a bit on the long side though.
Old set were the originals, so as MattThe Hat says, they will last about 20 years.
Schadenfreude - the German's haven't got a word for that.
threelander
Post Wed Nov 02, 2011 9:15 pm
they say magnicore are very good
mineralblue
Rocking Horse Poo
Post Wed Nov 02, 2011 9:51 pm
cheers fellas, appreciated.
Post Wed Nov 02, 2011 10:15 pm
A problem that most find when they buy non genuine replacement leads is that they come without the cylinder identification sensor on lead #6.
I run nearly all my BMWs, including E30s, on LPG, and this places a much greater strain on ignition components than if the car was running on petrol. All the ones that have leads, rather than COP, are running on the original leads, which, when tested, show no deterioration at all from new. The only leads I have ever replaced on a BMW are those that have been physically damaged by either the current or previous owners removing leads from the plugs by pulling on the lead rather than the cap.
If you were running something like a Land Rover on LPG, then apparently Magnecor leads are a good idea, since new OE leads are reputed to last about a year, but E30s were specified to a somewhat higher level than Land Rover!
mineralblue
Rocking Horse Poo
Post Wed Nov 02, 2011 10:21 pm
Thank you squire. OEM it will be. And I can vouch for the lower grade at Land Rover, having worked there for 18 years.
andy523
Post Sat Nov 05, 2011 12:44 pm
i bought magnecor 8mm leads with the sensor, not cheap at 180 quid but look the part and run fine.
