S50 swap
jimbob88
Post Tue Nov 01, 2011 4:31 pm
I have just been tasked by a friend to convert his 318i to an s50b32, now i've already done an m52b28 on my own cabby and just wanted to ask are there any mjor differences between the 2 conversions? Same rads, fans, better engine mounts? temp sensors etc
Any info greatly appreciated
power corrupts.....absolute power corrupts absolutely
My car
Post Tue Nov 01, 2011 4:38 pm
Different rads, different engine mounts, temp sensor the same, different manifolds/exhaust, different wiring, oil cooler.
jimbob88
Post Tue Nov 01, 2011 5:12 pm
Thanks for the tips jhonno. Hopefully danthe is sorting looms, akg mounts are about to be ordered, manifold is being modded by mosely motorsport Can i ask which rad/fan ?
My car
penton08
Post Tue Nov 01, 2011 5:46 pm
E36 m3 rad, The A/C fan from a E36 m3 can be made to fit using e30 m3 fan brackets and a bit of fiddling. Or any other fan that fits in the hole.
jimbob88
Post Tue Nov 01, 2011 6:01 pm
Spot on thanks lads :)
My car
jimbob88
Post Tue Nov 01, 2011 7:58 pm
Non aircon rad as per m52 swap?
My car
Post Tue Nov 01, 2011 8:20 pm
You can use the M52 type aircon spec rad, perfectly capable for road use, ive used one before and its fine, I would only use it with an oil cooler though.
If its going to get hammered round a race track I would use nothing less than the S50 rad
jimbob88
Post Tue Nov 01, 2011 8:32 pm
Ok dan thanks, its just for road use :)
My car
jonnie
Post Tue Nov 01, 2011 9:03 pm
Stick an s50 one in there, they can be had for about £50.
jimbob88
Post Tue Nov 01, 2011 9:17 pm
Whats the differene mate? Bigger core? Does it still need to be an aircon model rad with the "cutout" in the bottom corner?
My car
Post Tue Nov 01, 2011 9:30 pm
The core is about the same IIRC, just the S50 rad is about 3 inches wider, this means you need a separate expansion tank so if you want a proper airbox you have to mount it on the battery tray and pipe it all up.
E36 Aircon spec rad has the tank on the side so you can fit an airbox next to it without problems.
Cone filters FTL :)
Post Wed Nov 02, 2011 12:04 am
Has to be an S50 rad imo.
Mosley are modding the manifold?! How?! BTB or nothing in my experience..
jimbob88
Post Wed Nov 02, 2011 8:18 am
I think he said they're modding the 6th but im just here to do the spanner weilding :)
My car
penton08
Post Wed Nov 02, 2011 5:05 pm
jimbob88 wrote:I think he said they're modding the 6th but im just here to do the spanner weilding :)
Is the car left or right hand drive?
jimbob88
Post Wed Nov 02, 2011 5:12 pm
Right hand mate
My car
