ecu 320i ecu325i
imye30
Post Tue Nov 01, 2011 7:13 pm
did a engine swap over the weekend 320i to a 325i but i left the 320i ecu in ran grate changed over back to the 325i ecu an does not seam as smooth running will i need to get the engine tunned up
Post Tue Nov 01, 2011 7:20 pm
imy leave it run for a bit to "learn" the ECU... did you end up using that injector loom ?
HairyScreech
Post Tue Nov 01, 2011 7:22 pm
it will be grumpy for about 10 mins until it finds its idle positions.
other than that the 320 ecu should just take the 325 chip as they are practically the same unit.
imye30
Post Tue Nov 01, 2011 8:28 pm
cheers for advice but with matching ecu in an wen a rev it just slightly above one its starts to grumble not smooth say like a very light miss fire
imye30
Post Tue Nov 01, 2011 8:58 pm
bump
HairyScreech
Post Tue Nov 01, 2011 9:08 pm
what injectors did you use, what was the donor engine, what fuel pressure regulator is on it and what ecu chip? if any?
imye30
Post Tue Nov 01, 2011 9:32 pm
i had a f reg 325i an then i bought a j reg 320i so just put the 325i in the j reg an kept all the parts as they were apart from new plugs oil change new clutch ecu the same one that was linked to the f reg 325i
Post Fri Nov 25, 2011 11:27 pm
On initial start-up, you should let it idle for at least 10 minutes to learn the base idle settings, then switch off, then go for a drive using all the gears and all the rev range, to fully transfer all the settings across.
You may need to reset the ECU by disconnecting it or the battery for an hour or so, then try again.
