Running lumpy
cypriot_boy_2k7
Post Tue Nov 01, 2011 5:37 pm
Right i've done all the research into this getting on my nerves now.
The car in question is an M40B16.
I have changed the following items and still runs rubbish on cold start and idle, then when its warm it runs better but not amazingly smooth.
Items changed for new bits are:
Blue temp sensor
Air flow boot
Spark Leads
Spark Plugs
Coil
Rotor arm
Dizzy cap
Throttle position Sensor
Cleaned the Idle control valve and it works.
Throttle Body Cleaned
How can the AFM be tested? as soon as its unplugged it runs crap and cuts out.
It smells very rich out of the exhaust.
It sometimes 8/10 does not fire on all cylinders, considering there is only 4 it sounds like a spluttering machine.
The car was sat for 3 years and when was first brought ran perfect.
I have read about the crank position sensor on another site.
gnarkillius
Post Tue Nov 01, 2011 6:28 pm
Well I had idle troubel on another E30.
All I can add to what youve already checked/replaced is breather hoses? Are they looking a bit cruddy? Though you say sometimes it wont fire all cylinders, which tbh to me (non pro) sounds more electrical perhaps, rather than air flow.
Maybe a problem with ICV?
Anyaway, I found my ICV fault using this site, with a jetronic/motronic troubleshooter
http://www.unixnerd.demon.co.uk/motronic.html
e301988325i
Post Tue Nov 01, 2011 6:41 pm
Have you had the exhaust gas analysed (CO2) at a garage or similar, aiming for 1% at idle?
I said:
e30topless said:
lock the wife in there
cypriot_boy_2k7
Post Tue Nov 01, 2011 7:08 pm
i had the it done at a garage at time of mot which was when it was doing the same thing, i had to send my mot to dvla it was 1.?%
greg124
Post Wed Nov 02, 2011 9:17 pm
could it be sticky injector(s)?
This was suggested when my M40 felt like it was running on 3, but turned out to be HT leads
Schadenfreude - the German's haven't got a word for that.
zaust
Zone day release
Post Wed Nov 02, 2011 10:01 pm
Have you had a spray around the inlet with some wd to see if there's an air leak.
M30 Tech 1 Touring on gas.
cypriot_boy_2k7
Post Wed Nov 02, 2011 10:18 pm
Going to rebuild the injectors on the weekend, no airleaks sprays Yeeee old wd40 nothing
