Rad pipes pressure
blingsta
- Boost Junkie
If your viscous isn't working and the temp starts to creep up, is it normal for the pipes to build up pressure?
mrb27
even with a good working system there will be pressure in the hoses. but yes, the hotter the water gets, the more pressure will be built up.
blingsta
- Boost Junkie
Ok thanks, so I think the prob is my thermostat.. Temp stays very low with my viscous that is constanly locked but change the viscous to another from a working car and it doesn't lock when temp gets to half? I think I might just buy a new thermostat and viscous
mrb27
u do have the fan cowling in place yes? and even if you had a super fan which would cool a bus.. the temp should still be at just under half, anything other would point to a bad thermostat.
blingsta
- Boost Junkie
yep, fan cowling in place.. exact problem is that my viscous for some reason is constantly locked and the temp always stays in the blue or just a hairline over, which is all good and i dont mind that but the hot air that blows into the cabin isnt that great !!
i dont know if there is a thermostat in place or not? but if change my viscous around to another that i got 2nd hand (been told it worked ok on the car it came off from) the temp still takes quite along time to get to half, but the viscous doesnt lock !! and builds a bit of pressure in the rad pipes
im just going to buy a new thermostat and a new viscous to eliminate them..
mrb27
yh go get a new stat m8, as i said before, dont matter how powerful the fan is, the stat will still control the temp and sit around half way.. running a car in the blue will cause damage to the engine pretty fast too, and yes the pipes will gain pressure as it heats, the fan will only lock up once the temp is up and heat from the rad will stiffern it up. your first step is a thermostat.. as it always sits in the blue its either locked open or there isnt one there..
you may have a bit of messing around when bleeding the system so if you fill it up with water and it seems to run too hot it may be that there is air in the system.. dont just think its still broke
i norm have the front of the n/s front of the car jacked up a little when filling the system, and slowly fill it too.
blingsta
- Boost Junkie
all done me thinks
got a new stat and viscous today, took the housing off and no stat was in there
fitted new items, filled up rad, fired her up and let her idle for AGES !!!! temp went to a mm under half and no pressure in pipes
went for a drive and temp stayed in same place, viscous still didnt lock up, but im happy that it didnt creep up.
i'll drive it around 2moro to try and get the rad hot enough for the viscous to lock..
thanks for your help mate
What do you mean, "no pressure in pipes"? When up to temp., the prssure in the pipes should be 1.4 or 2.0 bar, depending on model. With no pressure, internal local boiling will occur.
blingsta
- Boost Junkie
What I meant by no pressure Brian is that the pipes are not as pressurised as before..
mrb27
the pipes should still feel pretty firm, just watch it for a few days, it can take a while for any trapped air to work it way to the t.stat body. after cooling system work i norm open the bleed valve every few days for a week to let any built up air out
