Fuel Tank Questions
mb15
Post Mon Oct 31, 2011 4:26 pm
Facelift 320i
Just replaced my fuel pump and the it has the 2 fuel lines coming out of the top. The one facing the rear of the tank is blanked off with a bolt and jubilee clip :?
What would this one be for?
When the fuel gauge shows empty i top up and it will only ever take £38 worth at the pumps.
Morat
Post Tue Nov 01, 2011 3:46 pm
How many litres is £38?
Also, have you seen your low fuel light come on? they're usually far more reliable than the gauge. It's well worth driving with a can of fuel in the boot and leaving it until the light comes on if you're not sure.
gnarkillius
Post Tue Nov 01, 2011 4:00 pm
Hmm,. I seem to remember a thread concerning a fellow who had put the lower capacity fuel tank in his car, and the gauge then read much higher than what was actually in there.
Ill have a gander and see if I can find it.
Either the gauge or sender is playing up - £38 is only about 30 litres of fuel - a facelift 320i should have a 63 litre tank.
There will be a fuel feed and return and additional pipes for the breather system. You can't blank off the feed or return so it must be the breather which has been butchered :roll:
mb15
Post Tue Nov 01, 2011 4:52 pm
I have vdo dial cluster in my car, i had to change them when i had problems with the old set. Low level light has never been on.
Do they read the same as the newer clusters?
Also a vdo sender on the pump cradle.
I think someone has been at it before me and i seem to have a mixture of old and new components!
Cheers for the help, rob any ideas where this breather hose should connect to?
penton08
Post Tue Nov 01, 2011 5:40 pm
It sounds like someone has swapped the pump and sender. The blanked off pipe would of been the return, Your return should be in to the tank itself so no need to worry about that. The fuel gauge issues will be down to the sender and the gauge not being matched, Ie... sender from a small tank, gauge from a large tank.
