Lee Parkes' E30 Alpina B10.
zaust
- Zone day release
leeparkes
Plus i dont know if it makes a difference but these ECU's are 20+ years old now.
I too thought these 172/3/9 ECU's were reliable, apparently not.
shedrool83
leeparkes
Cheers.
Well, ive been using the car all week and its running a lot better but tbh its still not 100% Im nipping to Hi-tech in the morning to see when they can book me in to get it on the rollers.
After that im considering loosing the standard air box
its so close to the exhaust manifold plus the trumpet in the end of the box doesnt fit right so imo it can be bettered, the plan is to build an air tight shield where the washer bottle/airbox sits taking cold air from the headlights also the hole where the aircon sits can be used taking air from the air dam next to the fog light. Ive already got the filter, its a massive K&N about 12' long capable of handling 500hp.
leeparkes
Just got in from collecting the kids from the out laws, on the way there i put a bruv in the weeds in his E46 330i, the look on there faces.
- E30 Zone Meets/Events Team
She looks hot to trot now my good man
Hope you get warp drive sorted out
leeparkes
Me too.E30BeemerLad wrote:Hope you get warp drive sorted out
Still undecided about the Exips though, i love the style but i cant get 225 tyres on without fouling the arch
Worth some arch rolling for some proper sized boots?
leeparkes
There already rolled flat with a very light flare.
staley_turbo
This is exactly what I've been planning. Should work realy good if you do it well.the plan is to build an air tight shield where the washer bottle/airbox sits taking cold air from the headlights
leeparkes
Ive already cut a template out of fibre board, left about a 10mm gap all around and ive got an old bonnet rubber to seal it.
Where's the best place to get pipework, needs to be around 80mm diameter also rubber/silicone hoses?
leeparkes
Oh and i popped into hi-tech, its booked in for Friday.
leeparkes
Im too busy Friday so its Monday now.leeparkes wrote:Oh and i popped into hi-tech, its booked in for Friday.
Dont if its just me but it feels like the problem is coming back, the smoothness has gone out of it a bit.
staley_turbo
Its all in your head!
leeparkes
Your probably right.
Fingers crossed!
The new wheels look great but 205 stretched wrongness is no good.
Ever thought about relocating the TB the the other side of the inlet like on the B10 Biturbo?
You could then position the air box on the correct side for an E30, away from the exhaust manifold.
zaust
- Zone day release
leeparkes
It did cross my mind to put the TB on the other side but use a different TB like Andy (Andy335touring) did, but iirc he used some twin butterfly affair from a yank. If i find the thread ill post it up later.
But tbh the work involved transfering pipework, cables etc you may aswell go with itb's.
leeparkes
Andy335Touring
If you do it don't bother going as large as i did, just go 10-20% bigger.leeparkes wrote:It is a twin 60mm TB from a US Ford V8.![]()
http://www.e30zone.net/modules.php?name ... t=throttle
ITB's will be better but a lot more work and £££ !
leeparkes
Andy335Touring
Just noticed, that thread is five years old, time fly's !
I miss my old 335
I miss my old 335
leeparkes
Get another.Andy335Touring wrote:I miss my old 335
What happened to your old one? still on the zone?
Kedge
Blast from the pastAndy335Touring wrote:Just noticed, that thread is five years old, time fly's !![]()
I miss my old 335
zaust
- Zone day release
gareth
Alright mate
Andy335Touring
Sold ages ago just before i got made redundant, no idea where it's at now ?leeparkes wrote:
BTW, hi chaps
leeparkes
Just got back from Hi-tech Motorsport after the sesh on the rollers and the problem was the air flow meter. For one the flap spring was too tight.
Anyway its been recalibrated and now running spot on.
First run it made 243bhp with the AFM untouched, after about an hour of fiddling it made 257bhp @ 5450rpm BUT it made 285 lb ft @ 4200rpm.
Yes 285 lb ft, it even shocked the bloke!
Ive got to go back down next week to run it again as the print out is on normal paper so next time ill have a proper graph
I do have pics but there on my phone and cant upload them so if anyone wants to do the honors pm me your number and ill send them (short vid too)
Ill update later as to what he said to squeeze more power out of it.
Im well chuffed.
Im well chuffed.
Congratulations, good to hear you've got to the bottom of it.
Bristol_Jer
285 lb ft, thats a good torque figure!
She's a grunty fecker then
penton08
Good numbers there, I am hiding from you at the pod next year
