engine issues
greengoblin
any advice would be helpfull just having probs starting in the mornings or if left for an hour, it trys to start it hesitates and it starts will be fine all day if not left to long
greengoblin
forgot to mention ,its a e3o 320i tourer
Ajsingh
First thing to check would be the blue temp sensor as this could have failed and can cause all sorts of problems. It is located on the thermostat housing and is next to a brown coloured plug, top right corner of rocker cover.
http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug
Have a read of that and try all the testing methods.
I hope that helps
Aj
I hope that helps
Aj
E30 Crazy!
