CRUISE CONTROL
ed325i
Post Mon Feb 14, 2005 8:48 pm
Hi, can anyone tell me what bits I will need to fit cruise control to 325.
Simon
Post Mon Feb 14, 2005 9:24 pm
Actuator, mounts next to the airbox, has an extra throttle cable that connects to the throttle linkage.
Wiring loom.
Switch, mounts on the steering column.
Control unit, small ECU type box, mounts above glove box.
Small green connector that plugs into the back of the instrument cluster, some cars already have this fitted.
Clutch switch and bracket if a manual.
ed325i
Post Mon Feb 14, 2005 9:45 pm
Thanks simon. Is there a brake switch aswell?
Simon
Post Mon Feb 14, 2005 9:54 pm
ed325i wrote:Thanks simon. Is there a brake switch aswell?
It uses the original brake light switch, so as long as you've got one!!
