Limp mode again!!
craigieeb
Just been out, and it seems the car has gone in to limp mode, wont go past 5000 ish,
I havnt had it on the diagnostic yet but from experience,
it'll either be the cam or the crank sensor....AGAIN!!
so question...
I'v got spare cam and crank sensors here,
if i plugged them in would it get it's self out of limp mode? (if they are the problem)
or
do the codes need to be cleared in order for it to run out of limp mode?
so question...
or
M50 Turbo!!!
I shall say no more
craigieeb
Hmm just realised the spedo has stopped working aswell,
Wonder if thats just a red herring tho
M50 Turbo!!!
I shall say no more
whenever I have changed a cam or crank sensor in the past it has cured the problem and warp drive was restored without any code clearing etc
craigieeb
Cool, i'll swap them both over tomorrw, and see if that cures it,
If one of them has gone, i'll be looking in to the warranty of them
and see if I do anything with BMW....?
Probably tell me to fak off tho,
Tossers
Tossers
M50 Turbo!!!
I shall say no more
You need the speedo working mate, check the diff plug
craigieeb
I'll check that first then
M50 Turbo!!!
I shall say no more
samc
too much drink? or could it be an age related issuecraigieeb wrote:gone in to limp mode
craigieeb
I get worse after a bottle of jacky-d's
Have her walking like john wayne
M50 Turbo!!!
I shall say no more
craigieeb
Well, looks like the speedo not working wasnt a red herring after all,
Got under the back of the car and the wires to the diff sensor just fell apart in me hand,
So I cut it right back, stuck some fresh wire on...... Hey presto
Job done
Job done
M50 Turbo!!!
I shall say no more
craigieeb
Job done
Job done
M50 Turbo!!!
I shall say no more
jimbom30cab
- Tech 1 freak
nice job, i'll remember that for when it's my turn
e21Jason
M52 ecu needs a speed input from the dash cluster so if the speedo dies it goes into limp mode
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Some do, some donte21Jason wrote:M52 ecu needs a speed input from the dash cluster so if the speedo dies it goes into limp mode
rich318i
which ones do need a speed input? my e36 i used had abs and wont pass 5500rpm
