At the moment when I turn the lights on with the ignition on the lights on the heater panel light & speedo lights up but the computer does not light up I have changed the bulb with a working one I have taken 2 pics one with the camera flash of so you can see the lights on the heater panel working and the other with out a flash on and it looks like the computer display is working but it is not. Just to ad the nothing else lights up like the cig lighter, rear ash try.
At the moment this is sitting on the glovebox side it has enough wire to stretch over to the drivers side not sure where it goes......
This is from behind the trip computer just want to know if the yellow wire connects to anything
The 2 wires next to the orange relay which are red with white trace & brown with green trace
Looks like blue with brown trace does this connect to anything
green with purple trace & a brown wire
And last one any idea where this clips on to cant seem to find a place it would clip on to it is near some kind of ecu on the drivers side.
Any help would be appreciated thanks.
