Advise needed
chopper
Post Tue Oct 25, 2011 9:44 pm
Hi, I've just had my head rebuilt after it lost compression on 5 cylinders so now it back together it still won't start, it still sounds like it's ticking over too fast, the timing is set right, and it sparks, you can smell alot of fuel when cranking, but the plugs seem dry. I re-did a compression test and cylinder 1 is 100 and cylinder 6 is 75. So if all 6 had 75 I reckon I should start but be rough. Just wanted to know what other things I could check? It's an m20b25 auto.
greengoblin
Post Wed Oct 26, 2011 12:32 am
to do a compression test the battery needs to be fully charged take all plugs out throttle fully de pressed and crank untill needle stops on gauge and write the figures down , to check if its the piston ring pour a cap full of engine oil down each plug hole one at a time and fully depress throttle crank over if the gauge rises higher than before then its the rings. hope this helps.and ive got it right.
greengoblin
Post Wed Oct 26, 2011 12:35 am
could all so be valve clearance not set correctly
chopper
Post Wed Oct 26, 2011 4:59 pm
I'll do that compression check with the oil. The clearance is set to 0.25mm
mrb27
Post Wed Oct 26, 2011 6:57 pm
greengoblin wrote:to do a compression test the battery needs to be fully charged take all plugs out throttle fully de pressed and crank untill needle stops on gauge and write the figures down , to check if its the piston ring pour a cap full of engine oil down each plug hole one at a time and fully depress throttle crank over if the gauge rises higher than before then its the rings. hope this helps.and ive got it right.
i would have thought if the pressure remained the same it would be the rings, and if the pressure went up the rings are ok 8O
chopper
Post Wed Oct 26, 2011 7:08 pm
Just did the compression check and it raised a tad when I poured some oil in the spark hole,but the car never smoked or lost any oil just misfired for a few days then lost compression! :x
mrb27
Post Wed Oct 26, 2011 7:24 pm
when u say u had the head rebuilt.. what exactly did you have done m8? and what was cold starting like just before the compression went to poop?
chopper
Post Wed Oct 26, 2011 10:20 pm
Had new stem seals and had the valves cleaned and reseated, before loss of compression cold start was fine, just had the odd misfire and loss of power for a few seconds. After a week the car started to misfire more and more to a point where you were getting whiplash. I remember now that a puff of black smoke came out of the exhaust before it died but it wasn't smoking constantly.
mrb27
Post Thu Oct 27, 2011 11:18 pm
how u gettin on m8?
to lose compression on 5 cylinders sounds like its more than a blown head gasket or rings..
sounds more like a cooked head!
if the head gasket was blown it would norm just affect the 1 cylinder, very unlikely for 5 piston rings to blow at once too..
sounds to me like it may have overheated and warped the head, had this on an old 318, you get a distintive sound when a head is warped... like its spinning over too fast as you said, if this is the case you will nees a head skim, i did pm you but with no reply, there are also other things to consider ie.. when refitting the head a knocked crank sensor would play mischief.. there are quite a few things to consider when rebuilding the top half.. let us know how its going eh :D
chopper
Post Fri Oct 28, 2011 1:09 pm
Hi, I called but no answer, the mechanic said there is deep scores on two cylinders, and that the bottom end is gone. The crank sensor is brand new, I can get hold of an running engine for £120 so may go down that route as I dont think I've got an easy fix for this problem!! I can get a head for £250 which has been skimmed and rebuilt or a skim and test on my head for £90. My friend did the headgasket a week before it lost compression, and the doughnut put instant gasket all over the head and it covered up a few of the small holes on the gasket, that why I reckon the head went again
mrb27
Post Fri Oct 28, 2011 6:00 pm
could have blocked a few water jackets then :eek: sounds like it might just be worth the £120 far a transplant then..
