air flow sensor m3 e30 problem
dn808e2
Post Wed Oct 26, 2011 11:03 pm
hi , my car has devepoled a small problem , engine doesn't run like it should , a. e. eratic idlying when ticking over, sounds like on 3 cylinders, i have checked spark plugs, loom, distributor , changed idle control valve, proble still exist, so i think if its a air flow sensor part number for m3 215 bhp is 1362 7 547 982, but for evo sport is 13 62 1 286 064 , can i use an evo one , cause i can find same part number as evo sport on an E34 530 (M30 ) ENGINE
and dont have to pay crazy money to the main dealer :D as still a few e34s are around for parts
kundiboy
Post Fri Oct 28, 2011 6:07 pm
Gasket blocks on the throttle bodies can leak and cause bad idling issues too. Have you checked these?
1988 Diamond Schwartz E30 M3
