starter motor
kman82
Recently my engine has been loosing fuel pressure and has been slow to start. Sometimes it fires on one cylinder first and as such sometimes the starter motor squeels on overrun. I've sent the injectors off to be serviced to hopefully fix that problem but I also have the inlet mani off so now's a good time to change the starter motor.
Firstly, do you lot think i need to change the starter at all as hopefully when the injectors are working as they should the car should fire first time. I have no way of testing this without putting everything back together again though.
Secondly, Has anyone had any luck in reconditioning a starter themselves, or is it just not worth the bother.
And thirdly, if I put a new starter on where should i get one from, BMW or would ECP be ok?
kolee
I'm also quite interested in this.
I get a good 2 seconds of squeal after starting my car. Its still working fine but its not a very classy noise when powering up the barge. (although i dont have any starting problems).
kman82
I've now got the starter off the car and have opened it up and cleaned some of it but the screws holding the motor and brush mechanism together are rounded off so looks like a service is out of the question - I wonder if someones been here before.
I'm reluctant to buy a brand new starter as this one isn't completely shot but at the same time will be so p1ssed off if I get everything back together again and it still overruns.
Are there any newer starters that might fit like from an E46 or something where i could get a newer second hand one?
kman82
I bit the bullet and replaced the starter motor in the end....
Is there any reason why i cant test the starter once i've fixed it back in place? I want to make sure I've got the teeth lined up etc. I've got the inlet manifold off and injector rail disconnected from C192? Would i try it on the ignition or is there a relay to jump?
Billwill
You can either run a lead from +12 volts directly to the starter solenoid wire that comes from the ignition... it is a black/yellow wire. That should click in the solenoid and engage and rotate the starter motor.
Or you can carefully short out the black/yellow wire to the thick positive lead on the solenoid as that lead goes directly to +12 volts on the battery in any case. This is the classic emergancy short-out with screwdriver method when you are stuck in the middle of nowhere and turning the ignition switch to Start does nothing.
kman82
Cool thanks, but is it ok to turn the engine over with the inlet maifold off and injectors diconnected?
Billwill
Should not be a problem for a short stint....leave the Ignition turned OFF so the motor will turn over but there will be no spark or fuel injection.....the ECU will not even know anything is happening!kman82 wrote:Cool thanks, but is it ok to turn the engine over with the inlet maifold off and injectors diconnected?
kman82
Ok that makes sense, thank you
Alternatively, you can use pins 11 and 14 in the diagnostic socket, thoughtfully placed there by BMW for the purpose!Billwill wrote:You can either run a lead from +12 volts directly to the starter solenoid wire that comes from the ignition... it is a black/yellow wire. That should click in the solenoid and engage and rotate the starter motor.
- **BANNED**
Has anybody made a tool that can be plugged into the diagnostic socket to use these functions?Brianmoooore wrote:Alternatively, you can use pins 11 and 14 in the diagnostic socket, thoughtfully placed there by BMW for the purpose!Billwill wrote:You can either run a lead from +12 volts directly to the starter solenoid wire that comes from the ignition... it is a black/yellow wire. That should click in the solenoid and engage and rotate the starter motor.
My eyesight fails to see the bloody tiny numbers...
Youth is wasted on the young.
kman82
that sounds a bit easier.... Is the diagnostic socket the one near the dipstick?
Barx325i
I'd be looking for the socket that has at least 14 pins
Near the top front left of the engine on M20s; on the bulkhead, just inside the fusebox on four pots. Big round socket with a cap screwed on it. (Smaller D shaped thing on early E30s).
Malc: You can buy fully populated plugs to suit the socket, connected by a lead to an OBD2 socket as part of diagnostics kit.
Barx325i
guilty feeling, but a man who is capable of diagnosing an M20 should really be adept at differentiating a multipin plug from anotherBrianmoooore wrote:Near the top front left of the engine on M20s; on the bulkhead, just inside the fusebox on four pots. Big round socket with a cap screwed on it.
kman82
right its safe to say i'm a bit f*cked off!! After replacing the starter motor and putting inlet mani and all the other gubbins back together the bloddy starter motor stills squeels!! I've made a quick vid...
What can this be? The starter motor is brand new from ECP, it was the dearest one they sell. I did have a peek inside at the flywheel(?) when i fitted it and the teeth i could see looked ok. Is something stopping the starter motor letting go of the flywheel maybe? Any thoughts would be appreciated as this noise is just not accetable!
kman82
Anyone got any suggestions of what i can do to sort this?
I'm thinking i'm going to have to take the starter (and inlet mani etc) back off to have a peek inside at the flywheel teeth. there's no easier way to look in there is there?
When i fitted the starter, i didn't grease the new gear / cog on the starter itself. Should i have?
TIA
TIA
lamby
shouldn,t need to take manifold off just to remove starter.i found a v long screwdriver held the bolt head enuff to remove starter nuts,bit fiddly,then a decent torch and turn engine and check teeth are uniform,as some ring gears are straight and some slanted but if there the same it should be ok.yes bit of lube never hurt on the cog.also you may have some holes on pass side bell housing that you can see ring gear without taking any thing off,do that first then grease it if it looks ok.
E30_Crazy
I don't think the squealing is an indication of anything, really. All three E30's I've owned (all of which wouldn't fire up correctly at some point...) have squealed if I sat on the starter longer than usual.
kman82
I still havn't had chance to take the starter motor off to look at the flywheel teeth yet but I realised today that if I start the car with my foot on the clutch it starts perfectly with no squeel!
Any ideas what it could be?
E30_Crazy
Maybe it is the clutch slipping? The jolting surge of rotation from the starter making the clutch and (pressure plate?) loose grip.
kman82
I recently had a garage change the clutch slave cylinder, could that be anything to do with it do you reckon? What do I need to do to fix it?
kman82
bump, do I need to look at changing the clutch or is there any adjustment that can be done?
I knew an E30 that made a squealing noise like that because the gasket plate wasnt fitted between the engine and gearbox.
Was it a lucas starter? Did you compare the pinion gear with your old starter?
kman82
I've been meaning to ask this for ages now.... After i changed the starter motor and put everything back together I noticed this bolt on my driveway. Does anyone recognise it? Is it anything to do with the flyweheel / clutch??..
leeparkes
Yes, its a bolt that holds the gearbox to the engine.
Or a starter motor bolt! We have no scale to judge the size of that bolt.leeparkes wrote:Yes, its a bolt that holds the gearbox to the engine.
kman82
sorry for late reply, been hectic over christmas!
Its defo not a starter motor bolt brian, much smaller and different head (torx?)...
Now you mention it lee, it does look a lot like part 5 here
http://www.realoem.com/bmw/showparts.do ... g=23&fg=10
guess i'll be under the car this weekend then before the gearbox falls out!
reckon this could be a reason i've got this screach at start up?
