Inlet leaks, Oil leaks and Power Steering Issues...
MattCyclone
Post Wed Oct 26, 2011 12:08 pm
Quick questions folks...
I am collating the bits to refresh the inlet side of the car, as it has suddenly started drinking fuel and there is the occasional little shudder when idling. I have checked the Blue Temp sensor and it seems ok readings wise but I might just put a new one in as I will be re-doing the coolant anyway...
So, questions (for the Brainmoores etc...)
1. I have inspected most of the rubber pipework and it seems ok, with a couple of tiny cracks which I am not sure go all the way through on the AFM-TB pipe - this normal? I was just going to clean and smear them with silicone or similar to make sure they are air tight
2. My AFM has been 'adjusted' sometime in the past (the tamperproof cover has been tampered with!) - is it better to buy a good, non tampered AFM or get some garage with a gas analyser to set it up? Guess it might depend on price! And before anyone tells me off, it was not me!
3. I have has the injectors done, the fuel pipes in the Engine bay are new as is the filter (well, a year old). Am replacing the ancient rocker breather pipe and will clean everything out... Anything else I am missing? Is it worth disturbing the inlet manifold - which I assume will need new gaskets if I do...
4. For the oil leaks, I am going to replace the 4 'D' seals at the rocker ends (the rocker cover seal is only a year old) and make sure everything is clean. I am also going to do the oil pressure release valve (which can be done with out oil going everywhere?) on the filter housing and I am contemplating the crank case to inlet manifold 'O' rings - but again not sure I want to disturb the manifold!
5. Finally - and I guess the most worrying - the PAS. I recently changed the fluid as it was grey and my MOT man mentioned I might have a link as there was a covering of PAS fluid down the outside of the reservoir and hoses. I did a full fluid swap and wiped down the reservoir/hoses but looking again it it seems to be leaking again. Do the reservoirs leak at all? I have checked and the fluid does not seem to have dropped much if at all
Also, occasionally (normally when starting up) I get very heavy steering for a second or 2. This a pump/belt (unknown age but looked ok when I did the fluid and seemed the correct tension) or rack issue? Any thoughts before I spend loads of cash I don't have on bits I don't need!
Sorry for the length, just putting an order in with Cotswolds and want to make sure I get the bits I need!
Many thanks,
Matt
kman82
Post Thu Oct 27, 2011 6:59 pm
1. You could try spraying a flamable spray like carb cleaner onto the cracks and see if there is a slight change in revs of the engine. If so renew the hose.
5. I had a slight leak with my hoses where they connect to the PAS bottle. I removed the original BMW clips and replaced with jubilee clips and made sure they were on there really tight! If your PAS fluid is grey its probably time for a thorough flush, you need to change the fluid at least twice to get all the old crap out.
MattCyclone
Post Thu Oct 27, 2011 8:13 pm
Thanks, might give the clips a check, though it almost looks like it is coming out through the seam on the PAS bottle... Will clean it up and check.
Did the fluid 3 times to make sure it was as flushed through as possible, seemed to be pretty clean once I had finished.
clipper
Post Thu Oct 27, 2011 9:17 pm
4: Filter housing valve gasket renewal made a lot of difference to mine with respect to oil leakage- And no, oil does not go everywhere, but valve bits when you finally get the circlip free will invariably go everywhere except where you can see them !
