1988 318i Fuel Gauge
swathers
My fuel gauge goes to full whenever I turn on the engine even when the tank is empty. Is this a common problem and can I fix this myself? I have little to none car fixing experience! If I can't fix it myself does anybody know how much the estimated cost would be to fix it?
Any help will be greatly received!
Grrrmachine
- E30 Zone Wiki / Team Member
swathers
Is it expensive to rectify?
Pull up and remove the rear seat cushion. Take off the inspection cover on the RH side, and pull the three pin plug off of the pump assembly.
Turn on the ignition and tell us what the gauge does.
swathers
I'll have to do this on friday or saturday but will let you know what happens
swathers
Ok, I've taken off the 3 pronged bit and the fuel gauge stays at empty.
In that case the the level sender is damaged/stuck. It's held in place by the four small screws and washers on the top, and pulls straight up. It will be full of petrol, which drains out of a small hole at the bottom, so have something to put it in and smoking is not recommended.
They commonly get damaged when some muppet tries to remove the fuel pump without removing the sender first, and dents the top of the case in against the hole in the tank.
Yo can try to dismantle and sort it, or replace it. All RH senders from E30s with internal fuel pumps are the same, whether from 55 litre or 62 litre tanks.
hazd31
Gonna jump on here, have had simular problems, Did have a look into it a year or so back, but failed to fix it.
Mine always reads empty, however when the tank does get low the fuel warning light still comes on. any ideas?
I will try the obove tomorrow though....
In your case you need to short the brown and brown/green wires together at the three pin plug, and report what happens to the gauge.hazd31 wrote:Gonna jump on here, have had simular problems, Did have a look into it a year or so back, but failed to fix it.
hazd31
linked the two, guage went just past a quater....Brianmoooore wrote:In your case you need to short the brown and brown/green wires together at the three pin plug, and report what happens to the gauge.hazd31 wrote:Gonna jump on here, have had simular problems, Did have a look into it a year or so back, but failed to fix it.
hazd31
any luck guys?
swathers
I know exactly where it is but it has two clips on the two rubber hoses coming off of the pump. I'm a bit apprehensive that if I get them off i'm never going to get them back on again and will be unable to use it as my daily commute. My old man has a friend who is a mechanic so going to get some tips from him before I start taking it apart!
You don't have to touch the hoses! Unscrew the four small nuts and lift the level sender up and out.
swathers
I've got a plastic sender that twists anti clockwise rather then unscrews
How many electrical plugs on this assembly?
swathers
Just the one
Sounds like you have a pre facelift tank set up, with an external fuel pump in front of the wheel arch.
Hoses should go on and off easily enough, and neither of them are under pressure, like one would be on a facelift pump.
