starting problems
greengoblin
Post Tue Oct 25, 2011 11:58 pm
been having a problem starting my 320i auto, up from cold and warm its cranking over trying to start but need to use gas peddle when it starts cuts out if i rev it for 10 seconds its fine. i was told not to use gas peddle when starting, just turn key and it should start
gnarkillius
Post Wed Oct 26, 2011 12:41 am
Could be many things, but I think the usual things to try are (off the top of my head and Im not a mech, just an owner of several E30s now) :- Spark plugs, check for corrosion/looseness etc.
ICV, check for gunk, clean her out.
Breather hoses, are they looking a bit worn out?
AirFlow Meter (AFM) or one of the temp sensors possibly?
Im not sure on 320 (year) check distributer if present, WD40 it up.
Possibly fuel pump? Can you hear it whirr to build pressure?
Fuelling deffo ok? Check filter, possible injectors?
Thats all I can think of at the mo, but I take it its a bit wet wherever you are. The dampness can get in the dizzy, so its a good one to check if its just started when the weather got damp.
Anyway, if Im wrong some pros will come along in a bit and go BS!!! But Im just recounting things Ive done to cure an engine unwilling to start off the key. You are right, it should start without any throttle.
Since it goes with some gas ICV gunked up might be a good bet actually thinking about it, but also if its started with the rain, get the WD40 out on electrical contacts.
