Replacing brake master cylinder ?
spiny
Post Tue Oct 25, 2011 9:45 am
Hi guys,
after reading through other threads it seems that my master cylinder is on the way out - I have 'poor' brakes and the pedal sinks to the floor if I keep it pressed.
so, whats involved in replacing it ? any tips ? and where would be the best place to get a replacement ?
also, and I'm not sure how related this is, I also have the 'loud hiss coming from the passeneger side dashboard' noise when I brake, I did a search and found a few threads about it but none on what to do to fix it, any info greatly received :)
it's a 325 tourer, if that makes a difference :)
Billwill
Post Tue Oct 25, 2011 12:43 pm
Are you sure you do not just need to bleed your system?
It is not easy to replace the master cylinder as it is difficult to bleed but it can be done.
I had the"hissing" sound coming from the passenger side dashboard ie. the brake Servo.
I was happy that the Servo was working as with the brake pedal firmly pressed while engine is off...the pedal should sink slightly as you start the motor.
If you lower the glove box, you will see the linkage going to the brake Servo. As the shaft enters the Servo, it goes through a small circular foam filter which allows air to enter behind the servo diaphram as the pedal is depressed. I found this foam filter to be completely rotten and falling apart so I cut up a new one using a bit of plastic foam...vacumed out the old foam pieces and fitted the new foam section to the Servo...."hissing" gone away now. :)
Post Tue Oct 25, 2011 1:25 pm
the loud hiss sounds like there could be a problem with your brake servo, either the outer casing has split due to rot, the diagphragm inside has failed or the vacum hose going from the inlet boot to the servo has failed.
May just be easier swapping over a complete servo & master cylinder from a breaker.
You would need to fully bleed your brake system after replacing the master cylinder
spiny
Post Tue Oct 25, 2011 2:35 pm
cool :)
I have already bled the brakes, but couldn't see any air coming out. I'll give it another go with some more fresh fluid and see if that helps :)
I'm using one of the Gunson easy bleed things that plugs into a tyre to give it pressure.
spbt1
Post Tue Oct 25, 2011 2:52 pm
I had the same issue with poor brakes and replaced the master cylinder with one from GSF and hey presto problem solved, i also pumped enough fluid through to ensure it was all new.
